Chain for 929 - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 09-02-2006, 7:48 PM Thread Starter
Reputation Power: 15
Chain for 929
Finally time for a new chain! what length should i get?, i went 1 down up front and +2 in the rear. I know couple of you said to get a x-ring chain
And not to use a clip style master link. Do the ones with the 8mm bolts work well trying to avoid spending 200+ to replace my chain! Thanks in advance
Bryce Auten is offline
post #2 of 9 Old 09-02-2006, 8:51 PM
Reputation Power: 19
Re: Chain for 929
i would go with the 520 conversion DID ERV3 w AFAM sprockets..
03' Blk/Tit CBR 954rr, Erion full system, PCIIIr, Scott's Damper, Vortex Frame Sliders, Galfer SS Lines, Rear Seat Cowl, flapper pinned.
vertical954rr is offline
post #3 of 9 Old 09-03-2006, 12:03 PM
flea954rr's Avatar
Re: Chain for 929
concur on doing the 520 conversion if you have to change, but sounds like you already have the gears. definitly go with an x-ring chain, also stake the master link, and either DID or RK is going to be a high qaulity chain, and whoever is selling it can tell you the # of links. i did the -1 in the front and don't know the # for -1/+2
flea954rr is offline
post #4 of 9 Old 09-03-2006, 12:09 PM
kawboy69's Avatar
Re: Chain for 929
kawboy69 is offline
post #5 of 9 Old 09-03-2006, 12:27 PM
Re: Chain for 929
15/45 = -1/+2 stock is 16/43 in USA for a 03'954
post #6 of 9 Old 09-03-2006, 1:32 PM
flea954rr's Avatar
Re: Chain for 929
ratios end up being slightly different: 15/45= .3333333 and 16/43= .372093
i have really never undestood the +2 in the back because it seems to negate what has been done to the front, but have never ridin that set up so have no opinion.
post #7 of 9 Old 09-03-2006, 1:47 PM
Re: Chain for 929
Climb on your mountain bike and set the chain on the largest ring up front and the smallest ring on back. Attempt to start riding.
Then switch the front down one ring up front. Attempt to start riding. Feel the acceleration difference?
Then switch the rear up two in the back. Attempt to start riding. Feel the acceleration difference?
-1/+2 will make you
seamus is offline
post #8 of 9 Old 09-04-2006, 12:10 AM
Re: Chain for 929
final drive ratio:
15/45 = 3.0
16/43 = 2.69
link to ratio calculator (scroll down page):
Cal-Sportbike - Sport bike parts & accessories, Speedo Healer, Galfer Brakes, GPR of Italy Exhaust, Brembo Brakes, Shogun Frame Sliders.
post #9 of 9 Old 09-04-2006, 2:52 AM
flea954rr's Avatar
Re: Chain for 929
i stand corrected, can't argue with the explanation which now makes perfect sense. thanks for enlightening me, and that's why i put the no opinion disclaimer.
Question about 929 Chain KODA93 Honda FireBlade 10 03-29-2006 8:21 AM
Well, if SYKOTYK is Chain Jr., and Chain is Chain, then I guess I'm Chain Sr. ConqSoft General Discussion 120 05-07-2005 11:12 AM
929 - chain/sprocket question replica Honda FireBlade 2 05-16-2004 6:44 PM
929 Chain JBird Honda FireBlade 12 10-14-2003 11:01 AM
