Chain goes up to swingarm? - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 09-15-2006, 2:40 PM Thread Starter
I'm wondering if i need to adjust the chain on my 929. The specs say 40-50mm freeplay and my chain seems to fall within this, but i've noticed i've started missing gears and getting a box of neutrals just as i'm about to hit a very scary corner! I can push the chain up so that it touches the swingarm. Is this normal? Am i measuring incorrectly, i measure from the top of the lower chain + push up= 40mm? Any ideas? thanks
CJ550 is offline
post #2 of 7 Old 09-15-2006, 4:55 PM
Re: Chain goes up to swingarm?
Are you pulling the chain down 1st when you measure it?It makes quite a difference.My 929 gearbox was a bit like yours if you weren't positive with the changes(allways change up on a false neutral).
I started using Spectro Gold oil and it made a huge difference,gears just snicked in nicely.
KiwiBlader is offline
post #3 of 7 Old 09-15-2006, 7:10 PM
Check here for some info.
abtech is offline
post #4 of 7 Old 09-16-2006, 1:33 AM
1.75 inches. Man that a ton more than it said in the manual for my 94 900RR. If I remember right it was 1 - 1 1/8 inches. Was the amount of slack different on the older 900RRs
dmack is offline
post #5 of 7 Old 09-16-2006, 6:42 AM Thread Starter
thanks, great info
CJ550 is offline
post #6 of 7 Old 09-16-2006, 8:44 AM
yes
abtech is offline
post #7 of 7 Old 09-16-2006, 10:46 AM
HondaGalToo's Avatar
Reputation Power: 32
I keep thinking mine looks loose, then I measure it and it's fine. Like Ab said, a smiling chain is a happy chain, and mine definitely "smiles".
HondaGalToo is offline
Delphi goes tits-up phobiaphobe Off-Topic 0 10-11-2005 1:03 PM
matt232 goes rubber side up matt232 Australia 71 09-19-2005 9:12 AM
Is Chain going to join up? deez Road Racing: Club / Amateur 13 11-09-2004 7:27 PM
Just Trying To Keep Up With Chain... bwhip General Discussion 14 07-14-2004 4:46 PM
