HELP! New CBR 1000RR Spewing Green Stuff - Honda Motorcycles - FireBlades.org
post #1 of 23 Old 10-13-2006, 9:21 PM Thread Starter
Need a tech to help me sleep
-- Brand new 2006 CBR 1000RR with 411 miles on the odometer. I have been very gentle with this bike - basically waiting for the 600 mile service before I have my way --
This evening I wanted to go for a ride -- here is what happend -->
10/13/06 7:00PM Prepare for ride
  • Opened garage door, wheeled CBR out to driveway and parked on side stand
  • Start engine noted idle seemed to be higher then normal
  • Noted rough idle and slight idle pulsation during first few seconds of running
  • Noted visible exhaust smoke very faint
  • Left bike to idle warm up
In the time it took to put on a jacket, helmet and gloves
Brother and wife start screaming and I quickly approach the motorcycle from inside garage
  • Thick white smoke emanating from side fairings, and front - blowing up and back
  • Electric fan could be heard
  • Noted antifreeze puddle on ground beneath motorcycle
  • Temp gauge reading at 206 Degrees Fahrenheit
  • Shut engine off immediately via on/off switch
  • Key Left On cooling fan remained running continuing to blow smoke back
  • Noted antifreeze spewing from front of radiator
  • Noted antifreeze on right side fairing
  • Noted antifreeze leaking from tube on lower right side of bike
  • Noted staining on header and radiator
  • CBR decals on right side fairing welted
  • Allowed bike to cool before wheeling into garage
  • Antifreeze continued to drip out
I doesn't look good --
Flash is offline
post #2 of 23 Old 10-13-2006, 9:25 PM
ND4SPD's Avatar
Reputation Power: 50
Re: HELP! New CBR 1000RR Spewing Green Stuff
Wait 'til it cools down and then make sure your radiator cap is on tight.
ND4SPD is offline
post #3 of 23 Old 10-13-2006, 9:27 PM Thread Starter
Cap is on tight - There is a split in the front of the radiator. I have pictures...bike was fine when I parked it.
Flash is offline
post #4 of 23 Old 10-13-2006, 9:29 PM
ND4SPD's Avatar
That's what warranty is for
By the way...you must be a cop...that's quite the attention to detail.
to the site.
ND4SPD is offline
post #5 of 23 Old 10-13-2006, 9:45 PM
booracer is offline
post #6 of 23 Old 10-13-2006, 9:50 PM Thread Starter
Dark Jedi - not a cop
Warranty is for Chevrolet -- I want a new bike! Think I'll get away with it? I bought a 1995 CBR 900RR in 1995 -- In 2003 I listed the bike on ebay with 6000 miles. I was feeling froggy so I listed it with a brief description --> 1995 CBR 900 RR - Adult owned - Descripition "FLAWLESS". I sold the bike for $6500 and my one word description was never disputed.
My point here is in my book - this bike should go to the pile - Ok maybe not the pile -- but you know this is the beginning of a nightmare - Honda built on a Monday.
Flash is offline
post #7 of 23 Old 10-13-2006, 10:29 PM
Administrator
Red Rider's Avatar
Reputation Power: 47
Your radiator splitting probably spewed coolant on the headers and caused all the white smoke. If the temp gauge only got to 206F than the engine never overheated. The bike is fine...and the radiator should be covered under warranty.
Red Rider is offline
post #8 of 23 Old 10-13-2006, 10:58 PM Thread Starter
Breathing easier BUT--
I thought the bike ran hot from day one. I have seen as high as 234 at idle. The fan came on and blew off some tremendous heat. I have hit 200 on the interstate - on the throttle a bit.
The decal on the right side blistered the second day I had the bike. Service said it was just the decal. The decal is now a mess -- blistered from the heat
What temp do you need to worry? Whats going through my mind now is melted rings, scratched cylinders and a head gasket in the spring. I have no experience with this type of probem. I know when you cook a car engine, somewhere down the road it pops the head. Am I out of line here?
Flash is offline
post #9 of 23 Old 10-13-2006, 11:29 PM
flea954rr's Avatar
to be honest, the bike sounds like its been running hot from the start. i own a 954, and even on a 100+ day on the freeway at speed only see 186-187. sitting at a stoplight 217 at the most, and the fan comes on at 215. the blistered decal deal would piss me off if it is the stock exhaust. i doubt that there has been any serious engine damage, but have it checked out.
from another completely anal person about maintenence and such i feel your pain.
flea954rr is offline
post #10 of 23 Old 10-14-2006, 10:05 AM
You shouldn't have a problem getting the bike fixed at a dealer under warranty.
1bad-eg is offline
post #11 of 23 Old 10-14-2006, 9:29 PM
CBR929RE's Avatar
Reputation Power: 39
a member on here (maybe Pete?) did enough bitching about a peeling decal to get the whole fairing replaced. press them a little and they should fix everything that went bad.
CBR929RE is offline
post #12 of 23 Old 10-14-2006, 9:43 PM Thread Starter
Recall on the 2006 CBR 1000RR
I wanted to say THANKS!
I took my bike to the dealer -- service indicated that there is a recall on the 2006 CBR 1000RR -- On certain bikes the radiator is missing bushings on the radiator mounts. The radiator is "rigid mounted" to the frame. The radiator will flex and crack. I was told it would take about a week to get my bike back and they would check into my other complaints.
Have your VIN checked to see if you are part of the recall.
Flash is offline
post #13 of 23 Old 10-15-2006, 1:12 AM
Reputation Power: 17
That would be your cooland.
rokitt51 is offline
post #14 of 23 Old 11-11-2006, 6:38 PM
oh!!! Anyone Know of this recall??
Ive got an Australian 06 model,havent heard of anything,must admit though it has ran hot since day 1.
giza is offline
post #15 of 23 Old 11-12-2006, 11:21 PM
I've got an ' 06 & it runs about 80 on a 30 degree day, even in a hurry it stays about the same. I haven't got stuck in any traffic yet so I can't help You there
Mdala is offline
cbr 1000rr will not start? help Hitcher Honda FireBlade 16 05-03-2006 12:38 PM
New member with head light question 04 CBR 1000RR Jakes 1000RR Honda FireBlade 1 02-03-2006 9:52 AM
2003 CBR 954RR new owner help!! aronious_p General Discussion 9 02-23-2005 1:00 PM
1000RR Cosmetic Stuff (lights, fender, etc) knip Honda FireBlade 4 04-25-2004 3:02 AM
check out new website for CBR type stuff! moregrip Honda FireBlade 4 08-27-2003 1:52 AM
