Fuel pump not priming - cause? - Honda Motorcycles - FireBlades.org
post #1 of 61 Old 10-13-2006, 10:22 PM Thread Starter
Quoted: 2 Post(s)
what causes the fuel pump not to prime when u turn on the switch?
01 cbr 929.
any help will be very apreciated.
cbr_df is offline
post #2 of 61 Old 10-13-2006, 10:35 PM
Re: question??????
Burnt fuse.
Mojave954 is offline
post #3 of 61 Old 10-13-2006, 10:41 PM Thread Starter
Quoted: 2 Post(s)
Re: question??????
is there any other fuses beside the fuse box, cuz i;ve checked them all seem allright.
cbr_df is offline
post #4 of 61 Old 10-13-2006, 10:48 PM
Administrator
Red Rider's Avatar
Reputation Power: 47
Re: question??????
Weak battery?
Red Rider is offline
post #5 of 61 Old 10-13-2006, 10:57 PM Thread Starter
Quoted: 2 Post(s)
Re: question??????
nope, batt is fully charged.
cbr_df is offline
post #6 of 61 Old 10-13-2006, 11:30 PM
flea954rr's Avatar
Re: question??????
kill switch on?
flea954rr is offline
post #7 of 61 Old 10-14-2006, 12:35 AM Thread Starter
Quoted: 2 Post(s)
Re: question??????
more info on that kill switch pls
cbr_df is offline
post #8 of 61 Old 10-14-2006, 12:42 AM
Re: question??????
For the pump to prime the key has to be on and the kill switch has to be set to run instead of off..
carp4 is offline
post #9 of 61 Old 10-14-2006, 12:43 AM Thread Starter
Quoted: 2 Post(s)
Re: question??????
sorry my bad, the kill switch is the red button right? so when you turn it on, the fuel pump starts to prime, but right now is not priming.
cbr_df is offline
post #10 of 61 Old 10-14-2006, 12:49 AM
Re: question??????
So what happens when you attempt to start the bike, does it do anything?
BladeRider is offline
post #11 of 61 Old 10-14-2006, 12:51 AM Thread Starter
Quoted: 2 Post(s)
Re: question??????
ok so first of all pump is not priming, engine cranks but do not run.
cbr_df is offline
post #12 of 61 Old 10-14-2006, 12:55 AM
Re: question??????
Ok so I would narrow it down to the pump or an electrical problem going to the pump. You need to see if it is getting power, if you checked the fuses and they are good that is about all you can do if you don't have a meter to check the feed.
EDIT: and that's just a guess I never worked on my fuel pump when I had my 929, just cars with fuel pump problems.
post #13 of 61 Old 10-14-2006, 12:59 AM Thread Starter
Quoted: 2 Post(s)
Re: question??????
yeah i've checked the feed to the pump using a voltimeter and when i turn on the kill switch it reads bout .02 volts, so the manual says that if there should be voltage for a few secs, if theres is replace the fuel pump, but the thing is that it doesnt says how many volts should i get from that connector.
cbr_df is offline
post #14 of 61 Old 10-14-2006, 2:35 AM
Re: question??????
Had the same prob with my 929. I replaced a clip on and the wire for the kill swith got separated. Take the kill switch off and look at the wires. It worked for me
187mustang is offline
post #15 of 61 Old 10-14-2006, 11:22 AM Thread Starter
Quoted: 2 Post(s)
Re: question??????
i already checked that, kill switch seems fine cuz when i turn it on i can hear a click from ones of the relays but the pump still not working.
cbr_df is offline
Fuel pump question Nickelii General Discussion 7 09-25-2006 12:24 PM
priming but no fuel ? stopsign Honda FireBlade 2 11-01-2005 2:02 PM
Bike's Fuel pump will not kick on xxshawnxx Honda FireBlade 6 05-31-2004 1:34 AM
fuel pump ?'s Shorgasm General Discussion 7 03-10-2004 8:17 PM
Fuel pump ND4SPD Towing / Transport 7 11-14-2003 2:24 PM
