servo motor/egcv problem/question - Honda Motorcycles - FireBlades.org
post #1 of 2 Old 10-17-2006, 1:36 PM Thread Starter
i have a 02 954 and i am getting the 3-5 FI error code. the servo motor is jacked. i can hear it trying, so i'm guessing the gears in it are stripped by now. i have already done the airbox flapper mod, but i want some input on how to proceed with the servo motor. i have a devil shotgun (1/2 or 3/4) system and a pciiir. currently the motor is stuck in the low position, which is killing my high-rpm performance.
1.) What is your experience/opinion with modding the EGCV so that it is constantly open? I have read that it takes away low-rpm power and possibly fuel milage. Any truth to this?
2.) If I decide to mod the EGCV to fully open: Is there any way to disable the FI warning without replacing the servo motor?
3.) If replacing the servo motor: Would you recommend a new one (~$165), or trolling ebay for one?
4.) If replacing the servo motor: I have read the 03 one is better at keeping debris out of it. Wondering if there is any experience with this. There are two listed in the microfiche, one ending with 750 and one ending with 640. Would the one with the higher number indicate the 03 model?
Thanks in advance.
-James
jawz0414 is offline
post #2 of 2 Old 10-18-2006, 11:32 PM
Reputation Power: 66
Send a message via Yahoo to bettingpython
Re: servo motor/egcv problem/question
No way for debris to get in the servo motor that is a sealed unit. And I dont know how it could happen, but it did to me. I had a small pebble under the cover that covers the exterior of the valve assembly it jammed the valve and caused the gears on my servo to strip. I bought my servo new from a dealership. If you troll e-bay you may or may not get a good working servo. If it's not good then your still gonna have to spend the bucks to get a good one. As for pinning the valve wide open I will have to defer that one to others on the board. To my knowledge the only way for the error light on the FI to be cleared is to install an operational servo motor.
bettingpython is offline
Servo motor ,ECU problem. tonyfireblade Honda FireBlade 7 10-09-2006 10:38 AM
Servo motor problem on '00 929 chaosExpanding Honda FireBlade 0 02-04-2006 11:18 AM
servo motor confusion..... tglass Honda FireBlade 5 06-08-2005 3:42 PM
servo motor help gnome954 Honda FireBlade 6 08-17-2004 10:46 AM
Servo Motor? Trackfan Honda FireBlade 3 10-12-2003 9:12 PM
