Who's tried this? (Fork oil lock) - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 10-28-2006, 11:39 AM Thread Starter
As some may remember, not but two weeks ago I slipped new springs and seals in my 1000rr. I used aftermarket seals becasue I thought they may have a higher quality; however they lasted about three sessions before they had an almost complete failure under heavy, sustained braking. So, my forks are back apart waiting on OEM replacements and I ran across this article. Peter Verdone Designs - Oil Locks I'll sum it up: Mounted on the dampening rod is an oil lock, which heavily restricts the last 10mm or so of suspension travel to avoid bottoming out. This can either be removed (for race bikes) or modified to lessen the amount of restriction (for track bikes which still could experience a squared bump on the street, but will have more effective travel for the track). Sounds like a no brainer to me, who wouldn't like another 10mm of suspension? Anyone have any experience with this? Thanks.
rotorblade is offline
post #2 of 8 Old 10-28-2006, 11:59 AM
Re: Who's tried this? (Fork oil lock)
not tried myself, but know the site & appreciate how the mod works
IMHO i'd be wary @ completely removing the oil lock.. bottoming the forks out could be very harsh & @ >10mm less front ride height right there & then could be very bad as you will almost certainly be on the brakes!
That said IMHO you only need a bit of oil lock to feel what the fork is doing & IMHO i'd modify the oil lock (as per PVD) to drop the 10mm to far less.. MAYBE say 4mm
Hope this helps?
all the 'IMHO' is cos i'm very wary about talkin in absolutes in regards to suspension & other 'personal' types of machine set up.
if you do remove it completely, make sure that A) your front fender dont hit the underside of the front fairing on full travel & B) you dont get hydraulic lock with your existing air gap
adzman is offline
post #3 of 8 Old 10-28-2006, 12:25 PM Thread Starter
I don't plan on completely removing it, but I would consider modifing it. Are you sure this will effect ride height?
post #4 of 8 Old 10-28-2006, 1:12 PM
My RC51 doesn't have it and it's really no big deal. You setup the oil level/weight a bit differently, but as long as you know what you're doing it works fine.
abtech is offline
post #5 of 8 Old 10-28-2006, 2:09 PM
only at the end of the fork stroke, not at any other time
adzman is offline
post #6 of 8 Old 10-28-2006, 2:10 PM
man u sorta summed that up in a sentance what i took paragraphs !!
cheers
adzman is offline
post #7 of 8 Old 10-28-2006, 3:23 PM
Interesting. I use my bike for commuting to work and back and the roads here are horrible. I often can feel the end travel and would like to increase the safety margin.
dattaway is offline
post #8 of 8 Old 10-28-2006, 3:33 PM Thread Starter
O.k., so if all I wanna do is drill some holes in it-as the website recommends starting with a single 1-2mm hole, where should I drill it? Should I keep it up towards the top where there already are some existing slots, or more towards the bottom? I want to do it, but am not exactly sure where to do it at. Any help?
oil lock.jpg‎
Fork oil. ReaperAZ Honda FireBlade 6 04-25-2005 5:52 PM
Anyone tried this beer? deez Off-Topic 30 12-15-2004 10:32 PM
Fork seals leaking after fork oil change mfifield Honda FireBlade 6 12-11-2004 8:25 AM
Has anyone tried this? Paul Honda FireBlade 3 10-23-2003 11:46 AM
Anyone tried this kind of oil? rockets25 Honda FireBlade 8 05-13-2003 11:43 PM
