954 stroker motor - Honda Motorcycles - FireBlades.org
post #1 of 24 Old 10-31-2006, 3:04 PM Thread Starter
Send a message via AIM to guber
954 stroker motor
just woundering if anyone has done it and what kind of gains would be expected
guber is offline
post #2 of 24 Old 10-31-2006, 10:53 PM
Sponsor
SilverBullet's Avatar
Reputation Power: 21
Re: 954 stroker motor
I didn't stroke mine, but to take a guess I would say between 165-175 rwhp depending on how big you went with it.
www.cycletrendz.com
2006 Northeast Dragway Points Champion
2005 Northeast Dragway Points Runner Up
SilverBullet is offline
post #3 of 24 Old 10-31-2006, 10:54 PM
Sponsor
Check out my shops website for a little info on mods other than stroking.
www.cycletrendz.com
post #4 of 24 Old 11-01-2006, 8:31 AM Thread Starter
thanks man I was just seeing what options I had because I'm rebuilding the motor this winter
guber is offline
post #5 of 24 Old 11-01-2006, 11:02 PM
CBR929RE's Avatar
Reputation Power: 39
you gonna get the stock crank stroked by falicon (or someone similar)? if you do let me know how much they want to do the work.
CBR929RE is offline
post #6 of 24 Old 11-01-2006, 11:05 PM
ND4SPD's Avatar
Reputation Power: 50
Why don't you just call and ask them yourself?
ND4SPD is offline
post #7 of 24 Old 11-01-2006, 11:13 PM
CBR929RE's Avatar
because you have to print out some order selection sheet then fill it out and fax it to them so they can fax it back (I think they fax it back rather than calling). I'm not really in a hurry to get it done.
CBR929RE is offline
post #8 of 24 Old 11-02-2006, 8:33 AM Thread Starter
they said $1000 to stroke it 4mm and balance it the only problem I've found is that I can't find anyone to make the rods for it
guber is offline
post #9 of 24 Old 11-02-2006, 4:22 PM
CBR929RE's Avatar
Falicon can't make some of their kniferod rods work for it?
maybe give Erion a call and see what they say. they ran a stroker motor in the 929 FX bike
CBR929RE is offline
post #10 of 24 Old 11-02-2006, 5:27 PM Thread Starter
falicon said they couldn't make them and erion uses a piston when they stroke it,the only problem I've herd when you do a piston instead of a rod is that it puts extra wear on the bearings
guber is offline
post #11 of 24 Old 11-02-2006, 7:33 PM
nedro's Avatar
Reputation Power: 27
Doesn't Carillo make any type of connecting rod you want? I think they will.
Ride Red
nedro is offline
post #12 of 24 Old 11-02-2006, 7:37 PM
nedro's Avatar
I'm a little tired right now, but wouldn't using a piston keep the rod angle exactly the same? And wouldn't shaving or altering the crank and or shortening the rod cause the angle to be more severe? I'm pretty sure I'm right, but like I said, I'm tired.
Ride Red
nedro is offline
post #13 of 24 Old 11-02-2006, 7:42 PM Thread Starter
when I talked to falicon they said it would be better to use a rod then a piston and I talked to corillo today, they wanted like $400 per rod I just don't know if I want to send that kind of money for the amount of gain
guber is offline
post #14 of 24 Old 11-02-2006, 7:47 PM
nedro's Avatar
Still tired. If you use a rod to stroke the engine, do you not need a piston with the wrist pin relocated higher up on the piston? Or the piston dome shaved?
edit, Wait, I think I mean lower on the piston. I think I'd better draw it out so I can get it straight.
Ride Red
nedro is offline
post #15 of 24 Old 11-02-2006, 7:58 PM Thread Starter
if you use a rod you can keep your stock pistons in it, at least thats what I was told
guber is offline
WTB: 954 Motor 02FBlade Wanted 0 04-17-2006 5:40 PM
WTB: 954 Motor Fong Wanted 0 04-04-2006 3:03 AM
954 motor in a 929 Trackho Honda FireBlade 7 04-16-2004 9:12 PM
954 MOTOR CBR629 Honda FireBlade 2 07-22-2003 12:27 PM
954 motor in 929 namike Honda FireBlade 20 06-11-2003 12:50 AM
