I'm thinking of lowering my 1k - Honda Motorcycles - FireBlades.org
post #1 of 33 Old 11-03-2006, 3:34 PM Thread Starter
I recently hurt my ankle playing football and it's really tough to park my bike now. I'm 5'6 and I never complained about 1k's height till recently. The front area of my boots/toes touch on both sides but I cant push to hard cause of my ankle. I already got off the bike a couple times to make my life easier by walking it but it's a pain in the buttox. Is there a way I can lower the front and rear an inch or so with out purchasing parts? I plan on raising the bike back to it's normal height in Spring.
p.s. I wont buy boots with heels cause thats just wrong
fireblade freak is offline
post #2 of 33 Old 11-03-2006, 3:39 PM
Re: I'm thinking of lowering my 1k
I'd suggest keeping off the bike until your ankle heals. It'd be a shame to dump it because your bum ankle gave out in the parking lot.
OSIRIS is offline
post #3 of 33 Old 11-03-2006, 3:43 PM Thread Starter
Yeah I almost dropped it a couple times already. This is my only transportation at the moment. I sold my car before I busted my ankle
post #4 of 33 Old 11-03-2006, 3:50 PM
HondaGalToo's Avatar
Reputation Power: 31
At 5'4", I always have to get off my bike to push it around when parking it. I'd rather deal with that than lower it, as lowering will affect handling and ground clearance.
I'd leave it as it is. Hey, at least when your ankle heals, you'll be able to resume parking it while you're on the bike, something I'll never be able to do!
HondaGalToo is offline
post #5 of 33 Old 11-03-2006, 4:05 PM
CBR929RE's Avatar
Reputation Power: 39
I try to park where I don't really have to do any maneuvering unless its forward under power. getting the bike turned while still riding so that I'm facing out of the parking spot helps. parking up a slight incline helps backing also.
CBR929RE is offline
post #6 of 33 Old 11-03-2006, 6:33 PM
You can put straps on the front but there's not much lowering that can be done out back without a couple of parts. Ebay could save you a couple of bucks, then sell the parts when you return it to stock.
You don't really have much riding time left before it's blisteringly cold up there.
seamus is offline
post #7 of 33 Old 11-03-2006, 8:10 PM Thread Starter
Wow you guys are short! Just kidding, I was hoping there was something the dealer can do with the original equiptment to lower the 1k but I guess not. Thanks anyway guys
post #8 of 33 Old 11-03-2006, 8:44 PM
Repeater's Avatar
Do you ride with good moto boots? alot of them have great ankle support.
Aliens general, everything about them is alien!
Repeater is offline
post #9 of 33 Old 11-29-2006, 5:38 AM
I have the same height as yours. I got tired of pushing and pulling the bike with the tips of my toes. So I purchased at eBay a lowering link for $100 with shipping. Those links have 1" and 3" lowering options. I chose the 1" which looked enough (2.5 cm). The seat height is now perfect. I can use almost all the bottom of my boots while sitting. The feeling is much better than before and gives confidence to short people like I am.
I didn't notice any difference in riding. I ride on public roads with my mates on early Saturday mornings and my relative speed (relative to the bunch) is the same. The handling seems to be the same as well.
The ground clearance is of course shorter but I don't care too much about that. I don't ride urban and don't need to climb on sidewalks.
I guess that the racing guys on a track will need to modify the front as well. By how much I can't say. Just setup your sag and try lowering the front by 0.2" (5 mm) quanta until you are satisfied with the handling and cornering feedbacks. Like others wrote before me, make small single-adjustments and write ASAP your remarks. I heard from one of my mates that weighing the rear and front on home scales, before and after the modification will tell you by how much you changed your weight balance. You just place the first wheel on the scale and write the weight. Then move the scale under rear wheel of the bike and write the second weight. If you then lower the front and reach the exact weights as with the stock link, you are almost at the factory settings with a 1" lower bike. All measurements should be very accurate: we are talking about differences of grams. Be sure to straight the bike to the perpendicular when weighing. You will know it when the weight is at maximum on the scale. A digital scale is necessary to reach the most accurate results.
By the way, in principle the sum of the 2 weights should give the total bike weight. However, because of the height of the scale, you will get a lower weight by a factor of cosine the angle the top of the scale forms with the ground contact of the unraised opposite wheel.
zorbalegrec is offline
post #10 of 33 Old 11-29-2006, 5:42 AM
Baketech's Avatar
Reputation Power: 42
You've probably been down this road already, but I used an Aircast inside my boot to give my ankle some support while it healed....allowed me to get on the bike a bit sooner than I had expected...
Sith Apprentice
CBR929 - VFR800 - VFR800
Baketech is offline
post #11 of 33 Old 11-29-2006, 2:12 PM
MSGT-R's Avatar
Wrap the ankle snugly and wear lace-up boots.
As for the lowering, I guess I'll have to document the procedure when I do it to mine next month. I did it before on a 600RR, but the forks weren't inverted. I went down 1.5" on that one, and shortened the seat. You have to stiffen the compression rate to keep it from bottoming during agressive riding.
But then again, I'm only 5'1" @ 125 lbs... I don't bottom it much unless I go fast over rough railroad crossings. I was loaded with full saddlebags that day (I thought I heard a scrape doing 50mph..). The front end will bottom under hard braking when lowered that far.
To a student: no,no,no...straighten then brake.
http://cbrider.com/
http://v4hondabbs.com/
MSGT-R is offline
post #12 of 33 Old 11-29-2006, 2:23 PM
If you lower the front that much without compensating and also lowering the back, it will change the geometry of the bike enough that it would likely affect stability.
I should write an article about this, but I strongly recommend that people whose inseam is less than the seat height of their bike adopt riding strategies other than messing with the suspension.
For instance, get your seat scooped out (replace foam with gel) and narrowed. Stock seats are usually quite cheap on ebay.
CBRVFR is offline
post #13 of 33 Old 11-29-2006, 2:30 PM
MSGT-R's Avatar
I did the whole package on that bike...
I had a machinist make me a turnbuckle style link that could be adjusted as needed to complement the front lowering. The bike was lowered the same amount front and rear so the geometry wasn't changed. The bike was never taken to the track, it was for street only. The kickstand was also shortened with a threaded adapter to fit.
If you replace foam with gel, it had better be bagged, because the gel attacks the vinyl covering and hardens it.
http://cbrider.com/
MSGT-R is offline
post #14 of 33 Old 11-29-2006, 2:39 PM
I just wanted to point out that at 6'2", I have never had any problem touching both feet to the ground while on any sport bike I have ever sat on.
Carry on.
BDA116 is offline
post #15 of 33 Old 11-29-2006, 2:42 PM
MSGT-R's Avatar
When you get tired of being tall, I'll trade 'ya!
http://cbrider.com/
MSGT-R is offline
I'm tired of cleaning my rear rim after lubing the chain!! dmack Honda FireBlade 28 06-19-2006 5:52 PM
Hold on tight...my 2005 Gixxer 1k ride, Part I. ReaperAZ General Discussion 11 08-29-2005 7:16 PM
Thinking of selling my 954RR........ :( Milo Honda FireBlade 27 02-26-2005 11:22 PM
I'm Back!! And I've had the best time of my life (PICS) alexandra Off-Topic 39 11-06-2004 10:06 AM
I'm thinking of gettin shy of the blade... fumbducker Off-Topic 7 09-25-2003 11:43 PM
