brake question - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 05-18-2003, 4:25 PM Thread Starter
Re: brake question
Hey guys, i just did a search to find a step by step procedure on how to bleed brakes ( never did it before) and abtech posted one but the link was dead, sooooooo
anyone find a link for this?
thanks
trey is offline
post #2 of 6 Old 05-18-2003, 5:18 PM
Re: brake question
Here is one of mine:
First off, throw the mighty vac in the dumpster. Secondly, I KNOW you have speed bleeders right? If not, then bleed BY HAND both lines at the calipers. Wait 5 minutes and repeat. Now wait five minutes and begin tapping the lines (with the handle of a large screwdriver) at the calipers and move up toward the junction. Tap the junction for about a minute, then wait another 5 minutes. Continue tapping the line until you reach the master cylinder banjo bolt. NOW crack the banjo at the master cylinder and very gently squeeze, and retighten. Repeat this procedure about 10 times.
Now rebleed the caliper bleeders (again by hand). I have found the mighty vac really adds air into the system and uses way more fluid than necessary to bleed the brakes. The hot setup (as I have mentioned in several posts) is to mount speed bleeders at the calipers, mount a bleeder banjo at the master cylinder (add a speed bleeder there too if you're feeling adventurous) and do the above procedure in about 1/5th of the time.
abtech is offline
post #3 of 6 Old 05-18-2003, 5:52 PM Thread Starter
Re: brake question
thanks, that pretty much helps, i'm going to atempt it with a buddy this weekend. whats the worse that can happen?
trey is offline
post #4 of 6 Old 05-18-2003, 5:53 PM Thread Starter
Re: brake question
I meant to laugh at the end of that last question ahha
trey is offline
post #5 of 6 Old 05-18-2003, 6:14 PM
Re: brake question
unmeasurable environmental damage and misalignment of at least 4 critical elements in the solar system . . .
abtech is offline
post #6 of 6 Old 05-18-2003, 7:31 PM
Reputation Power: 24
Re: brake question
abtech : whats the worse that can happen?
ratter is offline
New brake pad installation RaggedEdge Honda FireBlade 9 10-08-2004 8:39 AM
CRG brake and clutch levers question? K9inAZ Honda FireBlade 16 12-16-2003 2:25 AM
Galfer SBK brake line RapperWW Honda FireBlade 1 10-21-2003 1:01 AM
HRC brake pads question? K9inAZ Honda FireBlade 7 10-03-2003 4:37 PM
HRC brake pads question? K9inAZ Honda FireBlade 4 09-09-2003 3:01 PM
