How hard to change plugs on 954rr? - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 12-18-2006, 9:52 PM Thread Starter
Is this something that is relatively easy to do, or should I have a shop or dealer do it? I think it is like $200 with parts and labor at the local Honda dealer.
I used to change the plugs on my old Seca II, but that was easy as you had access to the plugs without having to remove the tank or anything.
I seem to recall someone saying that you could take off the fairings and some of the radiator bolts to swing that out of the way?
Whatcha guys think?
SquireSCA is offline
post #2 of 10 Old 12-18-2006, 9:56 PM
Re: How hard to change plugs on 954rr?
I have yet to do it myself, so this is all hearsay, but it's easier to go in through the top.
Take of the gas tank and the airbox and the plugs should be right there on top.
Gigolo Jason is offline
post #3 of 10 Old 12-18-2006, 10:00 PM Thread Starter
Hmmm... Tank takes 5 minutes to remove... Never removed the airbox though... is it hard?
post #4 of 10 Old 12-18-2006, 10:13 PM
CBR929RE's Avatar
Reputation Power: 39
airbox is pretty easy. take off all the bolts along the perimeter and the 2 in the middle and the top comes off. then unbolt the velocity stacks. unplug the coils off the plugs and then use the spark plug tool that came with the bike (regular spark plug sockets and wrenches are a huge pain in the ass).
not sure where you're getting the plugs from but I get them from Spark plug, Spark plug wire, spark plug gap, spark plug cross reference and ignition wires at Sparkplugs.com $12 each for Denso Iridiums.
CBR929RE is offline
post #5 of 10 Old 12-18-2006, 10:21 PM Thread Starter
Cool. Can I assume that the plugs for the 929 are the same as the 954rr?
post #6 of 10 Old 12-18-2006, 10:24 PM
CBR929RE's Avatar
I'm not positive but I assume so. my little writeup is based on doing them on a 929 but I can't see it being any different on a 954. the sparkplugs.com website will list the correct plugs for the bike.
CBR929RE is offline
post #7 of 10 Old 12-18-2006, 10:29 PM
flea954rr's Avatar
recently did mine, and agree with everything in the previous post, just a couple other things to add. if you have compressed air, after you remove the coil packs, and before you pull the plugs, blow out the area. make sure to put anti-seize on the new plug threads, and not to over tighten. one trick i use for plugs that the access is deep down is to use a piece of heater hose, or any hose that will firmly hold the plug, and use this to screw in the new plug until it seats, this way its impossible to cross thread as you will feel any resistance.
all in all not a hard job at all...
flea954rr is offline
post #8 of 10 Old 12-18-2006, 10:48 PM
I changed the plugs in my bike twice without removing the airbox. it was a MAJOR pain in the ass. I didnt remove the airbox because I didnt know that I could. That sounds like it would be a LOT easier. Next time i will be removing the airbox. Good luck with them plugs.
Removing the fairings can seem overwhelming at first but its actually very easy. Just take your time and remember what goes where. The one thing to remember with the fairing bolts is that there are three different bolt types. The regular thread, and two kinds that are threaded and have like a spacer on them. The two with the spacers are different from each other. One has a big spacer and the other is smaller. In case you forget which goes where, the bolts are threaded differently. So, if it seems reluctant going in, DO NOT FORCE IT. Also, if you look at the holes, you'll be able to tell which hole gets the bigger or smaller spaced bolt. And dont overtighten them bolts, it will make the holes in the fairing pull in.
shc76239 is offline
post #9 of 10 Old 12-19-2006, 5:14 AM
Top tip, added to your rep.
Cheers
Simon
r15suk is offline
post #10 of 10 Old 12-19-2006, 7:10 AM
sscottab's Avatar
Reputation Power: 17
the plugs are not hard to replace on the 954 just prop the tank up and remove the top of the air cleaner, remember to put a rag over the intake so nothing falls in while you are working. remove the coils and plugs, like someone said it is a good idea to blow the tube out before you remove the plugs and never seize is always a good idea and the rubber hose also works. just take your time and you should do fine.
2002 CBR954RR
scott
www.itriderz.com
sscottab is offline
How hard to refinish painted bodywork? sheepofblue General Discussion 18 07-31-2006 12:45 PM
How to change the air filter on CBR600RR Bignutz Honda CBR 600 4 04-28-2006 6:31 PM
How hard do you have to push??? symonjester General Discussion 34 05-08-2004 1:32 AM
How hard to remove the Gas Tank Creeper Honda RC51 5 04-14-2004 6:49 PM
How to change oil on a 954RR? just_john Honda FireBlade 8 07-02-2003 2:27 PM
