Leaking fuel - Honda Motorcycles - FireBlades.org
post #1 of 2 Old 12-21-2006, 11:56 PM Thread Starter
Leaking fuel
So I installed my new steering damper today and took the 954 out for a requisite spin. Riding along I can't help but smell gas, but the bike runs flawless. Upon returning home I find what appears to be the larger of two drain hoses leaking below the tank, actually a pretty good trickle. I replaced the line, but now it just leaks from below the bike. I stuck an allen wrench through the nipple up in to the tank and didn't find a check valve, so now I'm leaking from a line and don't even know it's original purpose. Any ideas?
Ben
maniac121 is offline
post #2 of 2 Old 12-23-2006, 9:04 PM Thread Starter
Re: Leaking fuel
So I got around to pulling the tank today. Not a difficult task, but messy. Honda silver soldered or brazed two steel lines insided the tank. The larger of which simply drains the ring around the filler neck. Mine developed a leak about half way down; from the gunk that was at the exit I'll assume it was corrosion. I blocked off the drain tube and I'll just have to remember not to overfill.
Hope this helps someone in the future,
Ben
Leaking 954 fuel tank air vent hose? Fabian Honda FireBlade 1 01-27-2013 7:39 PM
Fork Seals Leaking SilverBullet Honda FireBlade 25 09-21-2008 3:41 PM
fuel leaking from carb yulianusl Honda FireBlade 4 08-15-2007 6:01 PM
coolant leaking out BlueToy Honda FireBlade 6 04-01-2004 1:17 PM
Leaking coolant? mr_rua Honda FireBlade 3 02-09-2004 11:04 PM
