17" wheel bearings - 2001 forks - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 02-09-2007, 11:43 AM Thread Starter
I did the 17" wheel upgrade on my 95 RRS a while ago but since I smashed it up last month I am rebuilding it.
I have put in 2001 usd forks and yokes and i'm wondering what to do about the wheel.
Im not sure what bike the 17 I have came from but it bolted right into my bike with no issues what so ever. They seem to be the same size as my original RRS ones anyway.
Are the outer dimentions of the wheel bearings the same eg can I just buy bearings for a 2001? I guess ill have to mesure them to be sure, just wondered if anyone knew?
DarkStarCBR is offline
post #2 of 7 Old 02-09-2007, 7:44 PM
Re: 17" wheel bearings - 2001 forks
All I can help with is the size of bearings for a 17" wheel originally from a VFR or F3 which is the common adaptation /replacement for the original 16" wheel found on 1993-1999 900RR's.
O/S Diameter of the front wheel bearing is 1.653 inch.
I/S Diameter of the front wheel bearing is .785 to .786 inch range.
Axle Diameter for a 1993-1997 900RR is .785 inch.
These dimensions are the same for all of the following bikes and years:
1994-97 VFR 750.
1995-98 CBR600 F3.
1993-1997 CBR900RR.
To convert inches to mm divide by .03937
I don't know or have the measurements for the 929RR or 954RR. Most people use the 929 wheel if they are using the upside down forks from a 2000-2003. The other thing that should be considered is brake rotor spacing when mixing parts.
Fastrr is offline
post #3 of 7 Old 02-09-2007, 10:22 PM
Reputation Power: 15
Darkstar, sorry mate but you shouldn't use the wheel you fitted to your 95 900. The hub on the 93-97 900's was narrower (5mm each side) than 98-99 900RR's and the 929/954 wheels.
What that means is that your rotors will sit too far inboard with the 929 forks, so your rotors will not line up with the calipers. And the spacers wouldn't work either (too short). To get this to work, you'd need to machine new wider spacers for both the wheel and the calipers (to bring the calipers inboard). It would look like crap too.........and you'd still be stuck with really small 290mm rotors, when the 929/954 rotors are huge 330mm jobbies. And you wouldn't be able to use the the cool gold 929/954 calipers which have larger pistons and are teflon coated. By the way, one more benefit is that the 929/954 pad area is substantially larger than the 900RR too. Basically, the 929/954 brake system is superior in every way to the 900RR's. Then again, you'd expect that with evolution.
Keep in mind too that with a 17" wheel, you really should be using larger rotors. This is because compared to a 16" wheel, there is more reciprocating mass in the 17" wheel that larger rotors can help arrest. They look a hell of a lot better too.
Most that do this swap use the 3 spoke 929/954 wheel, but that combined with the 6 spoke 900RR rear wheel makes the setup look like ass! I found a solution though........ You can buy a 6 spoke wheel from the 2000-2001 RC51 (VTR1000) 'SP1' model bike. Now, that came with an ID of 20mm to match the 20mm axle, but the 929/954 axle is beefier at 25mm. So, you need to get some 929/954 bearings (same OD for all Firebkade wheels),the 929/954 centre collar, dust seals and wheel spacers. Then it will bolt up, and it will look right.
One thing myself, and another person who did this swap found was that the 929/954 spacers didn't work. They incorrectly oriented the wheel 1.5mm to the right. I ended up getting some new brass custom spacers machined for free (friend's dad owns a machine shop!), but you could get the left spacer reduced by 1.5mm, and get a new right spacer machined to be 1.5mm longer (they shouldn't cost more than $40 total to modify/make). Then your wheel will sit in the right place.
Just a word of warning on buying a used SP1 front wheel: Don't.
You can buy a new one for about USD$425 from ZANOTTI MOTOR CO. INC, Butler, PA 16001 - Motorcycle, ATV, Trikes, Golf Cars - plus you can get the bearings, collar, spacers and seals from them at a discount too. Used will set you back about $175-275, but it will probably need repowdercoating (another $60-100). Even then, you have no idea if it's been repaired in the past. The other guy who did the swap too bought an SP1 wheel on Ebay and when it arrived, the hub had mirofine cracks in it. Basically, you ask too much of a front wheel to take the risk of buying used. A front wheel is NOT a part to be cheap on! Just spend a little bit more and buy brand new.
Cheers!
Sime is offline
post #4 of 7 Old 02-11-2007, 5:14 AM Thread Starter
Cheers for the reply, lots of answers in there!
I see what you mean, that would look poop with the disks spaced out.
I'm having the rims re powder coated anyway so thats in the budget anyway .
I quite like the 3 sopke wheels, and wouldnt mind changing to them. Is there any problem fitting the rear into the 95 swinger?
post #5 of 7 Old 02-11-2007, 1:05 PM
Check this page out if you want. Many RC51 wheels here..
eBay - RC 51, RC 51 Wheels, Tires - buy and sell on eBay Motors
also try ebay UK
Fastrr is offline
post #6 of 7 Old 02-11-2007, 6:07 PM
That's the 'SP2' 5 spoke wheel.
Sime is offline
post #7 of 7 Old 02-12-2007, 8:14 AM
Quoted: 28 Post(s)
have a look at discs froma Super Blackbird - they fit the blade wheel but have a different offset which may be the ticket to get you out of trouble - sorry but I have no figures to quote you though......
machinehead is offline
98 900rr Wheel conversion from 16" to 17" Need Help! las1368 Honda FireBlade 45 04-18-2014 12:02 AM
Wheel Bearings BigTimmyRydesFast Honda FireBlade 17 04-21-2012 1:27 PM
94/95 900rrr 16" to 17" front wheel conversion neorazz Honda FireBlade 9 08-08-2006 12:20 AM
RRV 17" front wheel conversion?? RRVBlade Honda FireBlade 4 11-12-2004 2:00 PM
Steering damper/17" front wheel Congo Honda FireBlade 3 08-21-2004 6:43 PM
