fast idle issue - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 03-05-2007, 1:12 AM Thread Starter
fast idle issue
ok i searched thoroughly but am not finding what i need, I just got my bike back together from a motor swap and it is running smooth, but idling at about 1800 RPM, witht hwe idle adjustment all the way out. I have checked nearly everything I can think of and found no issues, throttle bodies and throttle were removed as one unit from one motor and put on the other, as were the airbox assembly and wiring harness, i did remove the HTEV valve from the exhaust and reinstalled it as it was removed. what else could be causing the fast idle on the new motor? shouldn't it idle the same since nothing was changed in regard to throttle position?
Firehawk is offline
post #2 of 6 Old 03-05-2007, 11:02 AM
Re: fast idle issue
does the throttle cable have to much tension on it?
Triax is offline
post #3 of 6 Old 03-08-2007, 12:21 AM Thread Starter
Re: fast idle issue
no it has slack at neutral setting
Firehawk is offline
post #4 of 6 Old 03-08-2007, 12:29 AM
Re: fast idle issue
perhaps the cold start adjustment isnt letting it go back to normal?
boostdemon is offline
post #5 of 6 Old 03-08-2007, 12:50 AM Thread Starter
Re: fast idle issue
i have it all the way out, messing with stuff I've manageed to get the idle down to 1500.
Firehawk is offline
post #6 of 6 Old 03-08-2007, 1:35 PM
Re: fast idle issue
Is there a butterfly valve on the throttle of these things? can it be stuck open a butt hair? maybe some dirt built up?
dblhelx is offline
Idle isue devilmanracing Honda FireBlade 5 12-12-2006 10:34 PM
Fast idle Diesel954 Honda FireBlade 6 01-06-2005 7:05 PM
Lumpy idle JWHT Honda FireBlade 9 07-26-2004 6:49 PM
1000rr Idle Mako Honda FireBlade 7 04-19-2004 11:48 PM
