Which wires for flush mounts? - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 03-10-2007, 12:26 PM Thread Starter
Installing front flush mounts on my 929. The new flush mounts have just two wires. There is a set of two, and a single wire that goes to the stock on each side. Which to use?
JeepinJeff is offline
post #2 of 11 Old 03-10-2007, 7:29 PM
Re: Which wires for flush mounts?
Just touch the wires to the stock wires until the signals work. Leave the signal on so when you make the right connections you'll see it.
dblhelx is offline
post #3 of 11 Old 03-10-2007, 9:35 PM
Buy a manual, it has a schematic in there. But seriously, putting my assaholic tendencies aside, cut the running light wire clean, fold it about 1 inch back on itself, and put heat shrink over it. That will keep you from shorting out on frame.
A.F.T.C.T.T.G. is offline
post #4 of 11 Old 03-10-2007, 11:03 PM
smkeatr's Avatar
Reputation Power: 21
Green is the ground. Honda's have running lights on the front, thus the 3rd wire. I melted 2 sets of flushmounts before I asked or did a search on this type of thread. There is plenty of info here on that topic.
smkeatr is offline
post #5 of 11 Old 03-10-2007, 11:10 PM
I just get so much joy saying this: BUY A SERVICE MANUAL.
That's almost euphoric.......
post #6 of 11 Old 03-10-2007, 11:32 PM
you can still maintain the runnin light feature by putting diodes inline with the running light wire and +blinker wire and then connecting them to the signal wire
the diodes keep electricty from going back up the wire and messing things up
also
as long as you know which one is the running light which can be just taped up and not used if you dont want to go the diode route
(use a volt meter, its the one thats hot when the signals are off)
the other two wires really dont matter what goes where
you can cross up +/- on the signal wires only
it will still function, two wire signals are not polarized
baxsom is offline
post #7 of 11 Old 03-11-2007, 5:37 AM
Reputation Power: 15
.....theres three wires right?
1 = Ground
1 = constant 12 volt power for running lights
1 = switched power for blinkers
If your flush mounts (like mine) only have two wires than you can only wire then for running lights or turn signals.........
Hook up the gound......then turn on the ignition and blinker and touch the wire to one of the two remaining wires....if it blinks than its hooked up to the switched power (blinker), if it stays on constant than its the 12 volt constant power (running lights)...
tdeal28 is offline
post #8 of 11 Old 03-11-2007, 10:43 AM
Not on LED's, they function on the same principal as a diode.
Current in the wrong diection, no light
Bat+ --->[--- GND = light
Bat+ ---]<--- GND = no light
post #9 of 11 Old 03-11-2007, 10:49 AM
he didnt say LEDs
which also brings up the point of
i have LEDs in my protons and they worked wiring both way
as well as the LEDs in my FE kit
both the wires coming out of that for each signal and plate light are the same color even
baxsom is offline
post #10 of 11 Old 03-11-2007, 11:01 AM
he didnt say LEDs
Really now!!!! I use LED's instead of diodes in my fuel injector drive cards in parts of the circuitry. I found they have the desired break voltage characteristics not available in an off the shelf diode package.
post #11 of 11 Old 03-11-2007, 3:24 PM Thread Starter
got them working, thanks, I do have a pdf version of the fsm but couldn't find the page that showed the colors for the wires, just the schmatics that showed the wires. Ah well, it's working. Thanks
Flush Mounts IRideChasey Honda FireBlade 19 09-11-2006 4:13 AM
Flush mounts Cmac Honda FireBlade 4 09-02-2006 12:50 PM
which size lockhart flush iv for the front? detourbeach Honda FireBlade 5 06-01-2006 8:56 PM
Blinker wires, which is which? (-/+) ? JohnnyInsano Honda FireBlade 3 01-19-2006 11:50 PM
LP IV flush mounts for the 929. Zygoat Honda FireBlade 2 02-13-2004 4:16 PM
