CBR 954 FI Code 32 HELP - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 04-14-2007, 2:16 PM Thread Starter
Hey Guys,
I wonder if someone might be able to help me out. I was riding my bike last night, and the FI light came on. I counted the blinks and it was a code 32. This morning I tried to turn on the bike, and it won't start. WHen I put in the key, and turn it to on, usually the front light and all the lights in the gauge would turn on before I would actually start it. Now, the only lights that come on are the directional lights on the cluster gauge.
Please Help............
dicedreams2000 is offline
post #2 of 6 Old 04-14-2007, 4:28 PM
Reputation Power: 17
Re: CBR 954 FI Code 32 HELP
and i dont believe that there is a code 32, but i am not completely sure anymore. Do a search just in case i am wrong.
Originally Posted by dicedreams2000 View Post
Hey Guys,
rokitt51 is offline
post #3 of 6 Old 04-14-2007, 5:45 PM Thread Starter
I tried to turn in on again, and it wouldn't turn on again, instead it was making a clicking sound.
I might have been wrong about the code, but since it won't turn on anymore, I can't check anymore...
Thanks again in advance.
post #4 of 6 Old 04-15-2007, 5:11 AM
33, 34, 35 would be the only fault codes that begin with 3, but all of those still show engine operating normally. My guess would be since the engine doesnt start "now". Its possible u could have been wrong on ur code. If it just clicks, i would check the connections on the battery. If that doesnt work....then try push starting it. IF it cranks, then ur starter could be giving u problems....=-)
ReSpEcT is offline
post #5 of 6 Old 04-15-2007, 8:06 AM
sscottab's Avatar
welcome to the org.
if the light came on while you where riding and after you turned it off it will not start now you may want to look at the battery or charge the battery and then try again because you may have lost the rectorfier or stator, when that happens the bike no longer has the ability to charge and will run on battery only and when the battery gets low it will cause all kinds of problems and can acully set false codes because not enough power to run correctly.
this will also cause the clicking when trying to start because not enough cca to turn the starter and engine over.
2002 CBR954RR
scott
www.itriderz.com
sscottab is offline
post #6 of 6 Old 04-15-2007, 10:27 AM
Administrator
Red Rider's Avatar
Reputation Power: 47
Are you getting any power? If so, you need to jump the service connector under the seat to reread what code(s) you're getting.
Red Rider is offline
CBR 954 code 32 dicedreams2000 Introductions 12 04-16-2007 6:07 PM
FI MIL Code 929yellowjacket Honda FireBlade 2 04-01-2007 11:41 AM
FI blinking code ReSpEcT Honda FireBlade 5 02-24-2007 10:26 AM
1000rr flashing FI code please help lvnspeed Honda FireBlade 15 02-28-2005 6:44 PM
FI Code question nags12 Honda FireBlade 2 01-15-2004 10:13 PM
