929 fuel tank help - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 04-29-2007, 11:17 PM Thread Starter
929 fuel tank help
ok, so i got a new tank and my set up been apart since an accident in jule, im putting back together, need to know the fuel pump install, i did it with the banjo bolt bung on shift n brake side but the line looks folded when i install, please help, or send pix. which side does the line bung on the pump go on, brake or shifter side?
and
how does the fuel line go onto the tank?
E_RacK is offline
post #2 of 7 Old 04-30-2007, 12:00 AM
Re: 929 fuel tank help
one is a fuel overflow hose that goes to the bottom of the fairing,and the other is the actual fuel line to supply fuel to the motor .you can't really screw it up as the 2 hoses are different sizes
Renegade929 is offline
post #3 of 7 Old 04-30-2007, 1:04 AM
Send a message via AIM to 2k929
....they should only fit one way. But if you are putting on a banjo bolt after removing, i would reccomend buying new crush washers to go on both sides of the fuel line. It will help drop the risk of a fuel leak
2k929 is offline
post #4 of 7 Old 04-30-2007, 2:36 AM Thread Starter
im actually inguiring about the banjo fitting on the fuel pump, does it go on shift side or the brake side, i know where all the other lines and electrical goes but also im wondering though, how the fuel line goes on the pump, the line has a metal fitting with a curve, does the curve point up, or down?
E_RacK is offline
post #5 of 7 Old 04-30-2007, 3:07 AM
it points to the right side of the bike
post #6 of 7 Old 05-01-2007, 1:59 AM
it points up to the right
Trendkiller is offline
post #7 of 7 Old 05-29-2007, 10:52 PM Thread Starter
got it guys, sorry for the late replay but i got it on, thank you. however, after about a month now my fuel pump wint prime n t's fine. i checked the right clip on its fine, i checked the relay's their fine, the wires look fine, one day it just stopped wirking, the only thing i did was fix my tail light turn signal wiring
E_RacK is offline
929 fuel tank removal clown Honda FireBlade 12 06-08-2016 12:40 AM
Custom Fuel Tank Fastrr Honda FireBlade 1 04-29-2007 7:05 AM
In need of "01" 929 Yellow/Black fuel tank Silent_Assassin Wanted 0 10-15-2006 11:37 PM
929 fuel tank robwrighthonda Honda FireBlade 10 01-06-2006 8:34 PM
