'97 RRV Blade Suspension Help/Suggestions? - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 04-30-2007, 7:54 AM Thread Starter
Hi Guys,
Was out for my first proper ride on the Blade since i bought it last night with a few mates, and on the way home i was running a bit late so took off down my fave stretch of road to make sure i was home in time. This was a totally enjoyable experience and also the first time i have pushed the bike on a fair bit
However, i noticed that under hard braking from high speed i was getting what i can probably best describe as "wallowing" from the front end, it wasnt an unsafe feeling, just that the front wheel seemed to be so slightly moving side to side. Once the brake was let off it tipped into the corners lovely and is very sure footed around the corners.
What would be the best thing to adjust to try and eradicate this wallowy feeling?
Cheers,
Rob
CBR600King is offline
post #2 of 7 Old 04-30-2007, 10:02 AM
97BladeRider's Avatar
Send a message via AIM to 97BladeRider
Re: '97 RRV Blade Suspension Help/Suggestions?
Try the following as a starting point and work form there. Remember to set your sag with full gear on.
Sport Bike Motorcycle Suspension Settings - Sportbike Review - Sport Rider
...CB
1997 CBR900RR
Ride Red, or Go Home!
97BladeRider is offline
post #3 of 7 Old 04-30-2007, 10:22 AM Thread Starter
Thanks 97BR, that will do just fine to get me going.
Rob
post #4 of 7 Old 04-30-2007, 10:40 AM
No Problemo...
...CB
1997 CBR900RR
post #5 of 7 Old 04-30-2007, 10:54 AM
Excess use of the rear brake can cause this effect too.... Try laying on the front only and see if it still happens.
DarkStarCBR is offline
post #6 of 7 Old 05-01-2007, 7:11 AM
some things u might want to check out at when ur front wheel feels like moving side to side;
front wheel bearings, front wheel axle, fork bushings (internals of the fork which we call it locally)
had my share of ur problem too few years ago when i first bought my bike. turned out to be the front wheel axle and collar which was not in proper condition.
another will be the worn fork bushings, will cause the fork to feel "loose and over-jerking up/down/left/right" but that seldom happens unless the fork has gone thru many crashes and not fully repaired/rebuilt.
moron900 is offline
post #7 of 7 Old 05-01-2007, 9:31 AM
1rr
I set up my bike with the sportbike suspension settings and realy helped.
The bike is so much better I can't belive it.my 2 cents is change to these
settings then go from there.
1rr is offline
1997 Fireblade RRV help needed rear wheel CBR600King Honda FireBlade 8 03-19-2007 12:55 PM
97 RRV Rear Suspension Help CBR600King Honda FireBlade 0 03-19-2007 12:46 PM
Swapping Bits - '97 Blade ashtanga Honda FireBlade 3 02-09-2007 6:19 AM
929 Suspension Suggestions Ivo Honda FireBlade 5 06-17-2004 3:17 AM
I need suggestions on Suspension DWC392 Honda FireBlade 5 10-21-2003 4:04 AM
