CBR954RR clicking sound? - Honda Motorcycles - FireBlades.org
post #1 of 13 Old 05-03-2007, 1:47 PM Thread Starter
I'm pretty sure this is a normal Honda trait from what I read but I just want to get some solid advice.
It clicks like valve train noise and/or cam chain tensioner.
Most noticeable around 3000rpm.
Should I even bother checking the valve clearances? The bike has ~5750 miles on it.
AND...How do I adjust the cam chain tensioner?
BadBrad is offline
post #2 of 13 Old 05-03-2007, 2:29 PM
Re: CBR954RR clicking sound?
i have a similar problem on mine at 10.000 km and honda change an hydraulic tensioner.the noise begin at 3000 and stop at 5000.
2 balls is offline
post #3 of 13 Old 05-03-2007, 5:59 PM
Honda's, especially 954's are known to be particularly noisy. I mean preventive measures are always good, but unless it major I wouldn't worry about it. The 954 is by no means a quiet bike, but it is the best bike out there
Ross954RR is offline
post #4 of 13 Old 05-03-2007, 6:05 PM Thread Starter
thanks man!!! i figured this. i did quite a bit of reading before deciding i wanted one. i test rode it before buying and noticed it right away. for the price i paid it would still be worth it if i have to get the valves adjusted. i might be able to do the valves myself if i can find the time.
by the way, i LOVE the 954!!!!!! it is the perfect bike for me. i'm 6'7 and 215lbs. i have pretty high standards for motorcycle performance and this bike delivers everywhere!!!! one of those standards is NOT paying $11k for a new 1000RR. this bike whoops serious asss!
BadBrad is offline
post #5 of 13 Old 05-03-2007, 10:37 PM
Reputation Power: 66
Send a message via Yahoo to bettingpython
Valve noise and CCT slap are perfectly normal on the 954. My wifes F4i is so quiet it bothers me. Your not gonna pull the 1000's down a straight but youve got gobs of torque and a lighter better handling bike. My suggestion would be no matter how smooth you are invest in a damper if the bike did not come with one, its wheel lifting tendencies under acceleration make any uncontrolled steering input a little exciting. I run my damper turned down almost all the way because I like to feel the input but a rapid oscillation never gets started because of the high speed damping.
bettingpython is offline
post #6 of 13 Old 05-04-2007, 11:50 AM Thread Starter
thanks for the comments on the noise and for the advice of getting a steering damper. i will be ordering one next week.
BadBrad is offline
post #7 of 13 Old 05-05-2007, 1:18 AM
No problem man, enjoy the bike.
post #8 of 13 Old 05-05-2007, 1:26 AM
A friend who is a bike tech did a valve clearance check on a very low mileage 954RR as part of a service check for his buddy who just bought the bike. One valve shim in particular was .001" too tight, others have found the same exact valve a problem on their 954RR. The fix is to buy the correct thickness of valve shim. Apprently is was a Honda factory issue and who knows why, I don't think anyone has found that answer yet.
Fastrr is offline
post #9 of 13 Old 05-14-2007, 5:03 PM
I am getting the same kind of noise after having an engine built for my 929. On the "old" motor it purred like a kitten, and NOW, tap tap tap tap tap tap. The dealership told me it was cam chain problem. Come to find out it is not a cam chain problem. The tensioners are automatic and mechanical. They do not require adjustment.
Tonight, I am going to pull the top end of the bike back a part and drop the valve cover off AGAIN to check valve clearance. I have heard the the 929 and especially the 954 are noisey...I just don't understand why it didn't make all the racket before.
Travis94ZX is offline
post #10 of 13 Old 05-14-2007, 5:05 PM Thread Starter
did changing the shim to the correct size eliminate the valve train noise?
BadBrad is offline
post #11 of 13 Old 08-11-2007, 9:12 PM
Any update on the valve train noise issue for 954s? Does a valve adjustment fix this?
pilotguy027 is offline
post #12 of 13 Old 08-11-2007, 11:58 PM
Just curious, but which valve was it? Intake or exhaust and which cylinder...?
Mogolf is offline
post #13 of 13 Old 08-13-2007, 12:12 PM
bump, i have this same noise... any details on this?
praylood_93 is offline
clicking coming from clutch nitrorider Honda CBR 600 4 01-23-2007 1:15 AM
954 clicking...not CCT psustang89 Honda FireBlade 4 06-07-2006 10:37 PM
CBR954RR opinions subzero Honda FireBlade 29 09-11-2004 5:08 PM
Clicking noise from the front Mavic Honda FireBlade 10 09-19-2003 11:03 AM
Clicking avatar for webpage? MedTechRR General Discussion 1 05-12-2003 1:16 AM
