something's wrong with this throttle - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 05-09-2007, 6:40 PM Thread Starter
Hello,
Just got a PCIII for my '00 929 and after setting it up i followed the first time use setup instructions.
Pressed the 3 buttons, Ignition ON, and cycled through Low, Med and Hi mixture setup.
Then when finished messing with the mixture, the bottom led of the P unit stayed lit. Nothing unusual i guess, but when i twisted the throttle (engine off) the leds on the PC cycled according to throtthle position but only in the first seven out of ten. at full throttle there were still 3 leds to go...
Wasn't this supposed to be at first led on idle and at the 10th led when full gas open?
I'll start messing up with maps later, but now on i'm concerned about this throttle thing. I haven't ridden another 929 so i can't check if the performance is the same as mine or not...
MotorGus is offline
post #2 of 5 Old 05-09-2007, 6:46 PM
Re: something's wrong with this throttle
when you hook up your laptop you will see the place to adjust your throttle position
logas is offline
post #3 of 5 Old 05-09-2007, 6:49 PM
look under the tools section hope this helps
logas is offline
post #4 of 5 Old 05-09-2007, 6:49 PM Thread Starter
That can be done with a non USB PCIII?
What if the previous owner messed up with the stock throttle setting???
MotorGus is offline
post #5 of 5 Old 05-09-2007, 6:59 PM
mine is the usb type and i was able to adjust the throttle via the laptop. call or email powercomander for instructions onthe non usb
logas is offline
What's wrong with this? abtech Honda FireBlade 25 04-20-2006 4:24 AM
What's wrong with this.....? BDA116 Road Racing: Professional 4 01-26-2006 2:02 PM
Whats wrong with this pic Joachim2311 Honda FireBlade 2 08-20-2004 11:47 PM
Whats wrong with this picture Perth_CBR1RR Australia 4 05-31-2004 7:46 PM
What's wrong with this picture? sweetonion Honda FireBlade 10 12-08-2003 7:37 PM
