cooling fan ? - Honda Motorcycles - FireBlades.org
post #1 of 14 Old 05-15-2007, 7:45 PM Thread Starter
cooling fan ?
at what point on my temp guage should my cooling fan start? 96 900RR, no numbers on guage....thanks!
beast351 is offline
post #2 of 14 Old 05-15-2007, 8:19 PM
Re: cooling fan ?
i believe its right about 200 deg. give or take a few.
Edit: Now that I really think about it, it's closer to 185 or 190. Sorry 'bout that. Mine has to be turned on manually. Don't ask. lol
Italgirl1971 is offline
post #3 of 14 Old 05-15-2007, 9:39 PM
Re: cooling fan ?
my 929 kicks on @ about 217F
Renegade929 is offline
post #4 of 14 Old 05-15-2007, 9:43 PM
Re: cooling fan ?
My 954 is at 214F
Mogolf is offline
post #5 of 14 Old 05-15-2007, 10:40 PM Thread Starter
Re: cooling fan ?
does anyone know where that is on my guage?....i don't have one of those whiz-bang new fangled digital read-outs...lol
it goes almost in the red in traffic, and no fan....
beast351 is offline
post #6 of 14 Old 05-15-2007, 11:31 PM
Re: cooling fan ?
Red is bad, almost red is probably where it should kick on.
zfrilly2 is offline
post #7 of 14 Old 05-16-2007, 12:43 AM
Re: cooling fan ?
did you check the connection at the fan,or perhaps your fuses ? I'm assuming the fan is not coming on at all,no matter how hot the bike get's ?
post #8 of 14 Old 05-16-2007, 12:49 AM
Re: cooling fan ?
i have an old school gauge like you and had similar problems. on my F3 there is a screw located between the temp stipe and the axis of the needle. now that my fan turns on (new fuse, battery, and RR later) it turns on if it goes just above the little screw. I have had mine get to the red before. it shouldn't get there. you need to figure it out soon, as summer hits you will over heat in traffic fast. first check the fuse, then connections.
slorider18 is offline
post #9 of 14 Old 05-16-2007, 7:53 AM
Re: cooling fan ?
that's odd. can you post up a pic of your cluster? Mine is a digital read just to the right of the RPMs.
btw... have you RTFM? if you don't have one, PM me and I'll send you what I have.
post #10 of 14 Old 05-16-2007, 5:41 PM Thread Starter
Re: cooling fan ?
" have you RTFM? "
please enlighten me....probably not...lol i'll try to post up a pic of the cluster later. can i post pics without hosting them here, ie, link to photobucket?
i think the fuse is ok, as i can jump the wire on the temp switch to ground and the fan runs. i thinki need a new temp switch.... thanks everybody!
beast351 is offline
post #11 of 14 Old 05-16-2007, 5:53 PM Thread Starter
Re: cooling fan ?
beast351 is offline
post #12 of 14 Old 05-16-2007, 5:58 PM
Re: cooling fan ?
" have you RTFM? "
RTFM = Read The F'ing Manual
post #13 of 14 Old 05-16-2007, 6:07 PM
Re: cooling fan ?
based on the pic, it should turn on just past the temp icon. so you checked to fuse and it's ok? from there check all the connections. work your way to the fan from the battery.
post #14 of 14 Old 05-16-2007, 7:13 PM Thread Starter
Re: cooling fan ?
thanks, ItalGirl.......i don't have one.....bike's had a hard life, and the manual must have gone the way of the do-do years ago....haven't gotten around to buying one....
thanks to slorider18 too!
beast351 is offline
954 cooling fluid drain... iec General Discussion 1 05-15-2007 9:34 AM
Cooling fan on 05 1000 RR Belch Honda FireBlade 2 03-30-2007 9:47 AM
cooling system question emazens Honda FireBlade 0 02-24-2007 2:34 PM
cooling fan problems out ride you Honda FireBlade 5 03-14-2006 12:39 PM
cooling question? jerseydrew Honda FireBlade 6 08-06-2005 3:08 AM
