throttle delay - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 05-23-2007, 1:36 AM Thread Starter
throttle delay
its all good when i get on the throttle, but when i let off its taking way too long to get back down in RPMs. I'm thinking throttle cable but i wanted to get some other opinions before i take the tank off.
dr_love is offline
post #2 of 8 Old 05-23-2007, 6:30 AM
Re: throttle delay
Does the throttle snap shut when the bikes not running? When you twist the grip and let go it should snap shut like a mouse trap. If its lazy on the return then yes, its to do with your cables. Could ether be old crusty cables or cable routing. I just fixed this problem on mine by replacing the pull cable and lubing the push, then re routing them.
If it does snap shut then could be the carb slides, fuel mixture something faulty. Best bet is get it in the dyno, the operator should be able to tell you what's up at once.
DarkStarCBR is offline
post #3 of 8 Old 05-23-2007, 6:47 AM
Re: throttle delay
Could also be the throttle return spring if the throttle doesn't snap shut, like said above ^
openclassRR is offline
post #4 of 8 Old 05-23-2007, 8:31 AM
Re: throttle delay
It could also be your grip. This happened to my buddy after a day at the track. His grip had worked it's way down against the bar end which provided just enough friction to keep it from returning on its own.
Can't hurt to check these little things first.
J
jrocket is offline
post #5 of 8 Old 05-23-2007, 10:44 AM
Re: throttle delay
J
+ 1
02 954 is offline
post #6 of 8 Old 05-23-2007, 10:47 AM
Re: throttle delay
J
This has happen to me as well. I actually trimmed my grip to keep it from happening so often.
sinfuldragon is offline
post #7 of 8 Old 05-23-2007, 10:49 AM
Re: throttle delay
My throttle tube has a raised bit that stops the grip sliding up it...
post #8 of 8 Old 05-23-2007, 12:20 PM Thread Starter
Re: throttle delay
Crusty cables it was... thanks guys. This forum is awesome, I just got the bike 3 weeks ago so hopefully I'm nearing the end of these problematic questions.
dr_love is offline
throttle question rcee14 Introductions 2 03-27-2007 1:07 PM
Don't Delay jaim Politics 0 04-04-2006 4:04 AM
And yet no mention of DeLay here. jaim Politics 85 10-20-2005 11:20 AM
Adjusting throttle roadrash929 Honda FireBlade 8 05-30-2004 11:19 AM
Dont delay, order now! G-Force Junkie Honda FireBlade 5 10-17-2003 12:17 PM
