95 blade regulator/rectifier relocation (Sime) - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 05-23-2007, 10:56 AM Thread Starter
Hi buddy, just a quick one... Just wondering if you have a pic of your relocation of the Rec Reg? I spent about an hour pissing around trying to find a new position for it but without extending the wires i'm having trouble finding somewhere else to put it.
Cheers buddy
DarkStarCBR is offline
post #2 of 5 Old 05-23-2007, 8:46 PM
Reputation Power: 15
Re: 95 blade regulator/rectifier relocation (Sime)
Sure thing...
http://www.rrzone.com/forums/attachm...8&d=1161825330
I bought a piece of 3mm thick aluminum and cut it to the profile of the subframe. I then sanded back the clear anodizing on the subframe, clamped the piece to the subframe, and then used 3 big rivets to attach it. I then took it to a welder who Tig welded the part (but that's not essential).
After mounting the rectifier, I ran a thick ground wire directly from the rectifier to the battery negative. And because the bottom part of the piece I used to mount the rectifier only butted up against the lower subframe arm (couldn't get it flush because the lower tube is bent toward the frame), I used JB-Weld to create a smooth fill.
Then I powdercoated the subframe and it all looked like it was meant to be there! If you didn't want to powdercoat, you could just as easily mask that section and spray paint it with a pressure pack can to match the subframe!
Sime is offline
post #3 of 5 Old 05-24-2007, 4:34 AM Thread Starter
Cheers buddy, think I was trying to over complicate things as usual lol
post #4 of 5 Old 09-05-2018, 9:03 PM
Quoted: 3 Post(s)
put PC 12v Fan over it.. it's like $4.. .. google "fan over rectifier"
Sebulva is offline
post #5 of 5 Old 09-06-2018, 3:53 AM
Quoted: 29 Post(s)
It's an 11 year old thread?!
Spaz is offline
regulator/rectifier yellow wires CBR629 Honda FireBlade 11 12-19-2010 11:55 PM
i need a Regulator Rectifier XBAJBUSX Honda CBR 1100XX 6 05-09-2007 9:15 PM
Honda Regulator/Rectifier Fastrr General Discussion 0 02-09-2007 11:20 PM
Voltage Regulator-Rectifier Fastrr Honda FireBlade 6 02-07-2007 4:51 PM
WTS Regulator/Rectifier 2000 CBR929RR seebeare929rr For Sale 0 06-27-2005 7:05 PM
