Error code - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 05-23-2007, 7:50 PM Thread Starter
Error code
Hi is there any one to help.
I have CBR929RR Hi-vix 2001 Uk model
When i start the bike after 1 minute i get from the dash FI 3 long ones and 5 short ones flashes of the red light.
Ive checked the hi-vix servo and valve and they work on another bike.
What else can be.
Thank you
Marin is offline
post #2 of 7 Old 05-24-2007, 3:47 PM
Re: Error code
The problem can be of the ECM. Try in other bike your ECM.
mad max rr is offline
post #3 of 7 Old 05-24-2007, 4:09 PM Thread Starter
Re: Error code
Thank you for the advice but i think the ECM is linked with the ignition key for each bike.
Marin is offline
post #4 of 7 Old 05-24-2007, 10:00 PM
Reputation Power: 66
Send a message via Yahoo to bettingpython
Re: Error code
The servo works????
if yes is there something jamming up the htev valve keeping it from turning?
does the servo turn on your bike with the cables disconnected? That should clear the error.
Ok cables disconnected and servo not working on your bike but does another bike means bad plug/wire connection on your bike.
bettingpython is offline
post #5 of 7 Old 05-24-2007, 10:01 PM
Re: Error code
Yes it is euro models have H.I.S.S. Would need ECU and Key from another bike to test this on your bike is all.
post #6 of 7 Old 05-24-2007, 11:40 PM
Re: Error code
#1 even with htev eliminated or wired wide open he will still want the servo connected so the FI light is not on all the time so he might as well trouble shoot and fix it.
#2 HISS disconnection is not an option unless he buy's a U.S. model ECU
post #7 of 7 Old 05-25-2007, 12:05 PM Thread Starter
Re: Error code
Thank you i will check all this next week and send you a feed back.
I appreciated you help.
Marin is offline
2000 929 Error Code 35 Duess Honda FireBlade 5 05-05-2006 1:24 PM
error code reader maRRtin Riding Gear / Luggage 1 09-03-2004 1:11 AM
Error Code, or just normal? itsdesignateddave Honda FireBlade 4 09-08-2003 8:18 PM
Error code question Fossil Honda FireBlade 2 09-06-2003 9:39 PM
Error Code 35 ? AfterShock Honda FireBlade 15 08-22-2003 1:35 AM
