95 CBR900RR Fuel Tank line Problem - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 06-16-2007, 11:50 PM Thread Starter
Send a message via MSN to gmly
Hi
Can anyone give me some help on the following weird problem
I bought a 95 CBR900RR a week ago runs great ride it home no problem
I notice the rubber spacers between tank and frame are missing when i start looking over bike and tank is a little wobbly
So I order them Put them on yesterday never took tank off just removed top bolt by steering head to lift tank up so slightly
Bike has not been started all week
Today i go to start it and runs fine for a minute or two then begins to starve itself for fuel, eventually dies and I try to restart and it wont start
I pull tank off to see if i can find out what is wrong
Notice there are three lines from tank
1 from fuel petcock to carbs
1 from tank to a tube that vents to atmosphere
and a smaller one that looks like it should be for vacuum to carbs to get fuel flowing once bike is being started and is running
This line is connected at tank but is not connected to anything else
I look around and cant see where it is supposed to go
I look at bottom of each carb boot and notice there is a brass plug with a rubber cap on it for #1 cyl all other cylinders have allen bolts in there
I am stumped as to did i pull line off somewhere while i was playing with tank installing those rubber spacers
Anyways I decide to pull the rubber cap off the brass fitting on #1 cyl and hook the small line to it
Put bike back together and turn fuel petcock on after a few seconds bike fires up and is running fine
Am I missing something as to where this line should really go to ?
Did I leave a vacuum port unplugged somewhere else??
Any thoughts,help,suggestions would be greatly appreciated
George
gmly is offline
post #2 of 8 Old 06-17-2007, 12:41 AM
Re: 95 CBR900RR Fuel Tank line Problem
I don't have a 900rr nor have I worked on one. It does sound like you have a vacum line open somewhere. The brass nipple, where others are allen bolts is where you do a carb sync from. Look around under the tank and see if you can find the lost vacum connection, as where you pulled off a cap is not where the third rubber line connects.
zfrilly2 is offline
post #3 of 8 Old 06-17-2007, 1:38 AM
l;./////> dohhh the new kitten won't let me type!
Ok the two small lines are just vent and overflow. not vacuum. They just open to atmosphere below the bike.
The ON position on the fuel selector knob only works for the first 4 gallons of fuel in the tank. The last .75 gallons or so will ONLY get to the carbs if the selector knob is turned to RESERVE.
Try that and get back to us.
Fastrr is offline
post #4 of 8 Old 06-17-2007, 3:48 AM
Reputation Power: 15
What capacity is it...893cc or 918cc?
You said there is only one line coming off the petcock?
If you have a true 95 model George, your 95 does not have a vacuum operated petcock. That feature was a part of the 96+ Fireblade.
Then again, it might be a 96 model made in 1995. Easy way to tell. See the main frame....see the triangle section on the main frame under the fuel tank? Does the triangle 'end' at the rearmost part of the fuel tank, or does it end underneath the tank with a little bit of the subframe square tubing going under the tank connecting to the frame?
As Fastrr said, it might be that your fuel level is too low and you had it set for the main tank, or maybe the petcock selector wasn't fully open?
Sime is offline
post #5 of 8 Old 06-17-2007, 10:07 AM Thread Starter
Hi
Thanks for all your input It is really appreciated
The model year of the bike is 1995 (sticker with model year and VIN in big letters is still on frame)and I am inclined to agree that it is only a vent tube
Frame ends right at rear of tank
This is weird
There was not much fuel in tank and what is there is left over from when I bought bike.
Also bike has been sitting for a while
gas does not smell right
It doesnt smell like varnish yet but I think i will drain it
I tried to open petcock while tank was off and there was no fuel coming out and that was my reason for the vacuum issue
gmly is offline
post #6 of 8 Old 06-17-2007, 2:56 PM
remember to put that vacuum cap plug back on the engine where it came from.
If you can, buy some SeaFoam fuel/engine cleaner, poor a couple ounces of that in an almost full or full tank of fresh gas. The stuff works great and won't harm anything. Just don't put more than 2 ounces in.
Fastrr is offline
post #7 of 8 Old 06-17-2007, 10:39 PM
And from what I hear with the seafoam.....wait for the clouds of smoke!!
Sime is offline
post #8 of 8 Old 06-17-2007, 10:41 PM
Well, if you had the petcock set to the 'on' position and the tank was at the 'reserve' level, that would explain why the bike wouldn't start.
Sime is offline
WTB> 93-95 CBR900RR swingarm and carrier skorpia Wanted 1 07-02-2007 8:13 PM
Fuel Line Problem urgent reefatx Honda FireBlade 11 08-30-2006 6:04 PM
Fuel Line Couplers? Trackfan Honda FireBlade 16 03-02-2004 3:49 AM
Fuel Line Size 2001 929rr Honda FireBlade 0 06-26-2003 9:47 PM
