95 front forks - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 07-08-2007, 8:19 AM Thread Starter
Quoted: 20 Post(s)
Reputation Power: 15
95 front forks
just been out on the blade and noticed thats its pissing fork oil do i only need to get the seals or is there other o rings i need to get as well.
jon 8214 is offline
post #2 of 9 Old 07-08-2007, 10:49 AM
Re: 95 front forks
The fork seals should be what you need. Do both forks at the same time, even if only one is leaking.
Sime is offline
post #3 of 9 Old 07-08-2007, 8:52 PM
Re: 95 front forks
If your dust seals ( the ones you see ) are cracked or hardened buy new ones. If you are able to, buy new fork bushings. The reason i say it is Honda recomends you change them all at the same time. When seperating the chrome tubes from the lowers it requires a "hammering" slide action which essentially uses the bushing as the hammer that drives the sections apart from each other.
I've redone the seals on my 95, if you need help just ask.
Fastrr is offline
post #4 of 9 Old 07-08-2007, 10:31 PM
Re: 95 front forks
Ok I noticed that I have the same prob. I have never attempted a fork seal job so I am probly gonna send it to the shop.
Does anyone have any suggestions about what I should tell the shop to do? Should I just tell to them to replace the seals and bushings? Anything else while they are in there? What should I expect to pay?
Ps. Only 2k miles on the 95 and already a leak!!
Thanks for any help.
sorry for the jackin the thread!!
NICK929 is offline
post #5 of 9 Old 07-09-2007, 12:56 AM
Re: 95 front forks
Locally in Phoenix Arizona the going rate to replace bushings, seals, and fork oil is $150 if you bring the forks in off the bike. about $250 if you bring the whole bike in. This is most likely based on $60-80 hr labor charge. I'm not sure what they charge in your area per hour. The price included parts.
You shouldn't really need any other parts. If your chrome slider tubes are scratched you may have to replace them at around $400-600 a pop. Light surface scratches can be smoothed down with 1000-1500 grit sandpaper.
Fastrr is offline
post #6 of 9 Old 07-13-2007, 4:38 AM Thread Starter
Quoted: 20 Post(s)
Re: 95 front forks
just an update got my forks stripped down last night and the oil seals were completely shot. was wondering what is a good make of fork oil to get ie viscosity etc
jon 8214 is offline
post #7 of 9 Old 07-13-2007, 4:42 AM
Re: 95 front forks
If that includes the seals, bushings and oil, that is a fair price.
Yep. If the tubes need replacing, that would definitely be the time to update to the 929/954 upside down fork front end and 17" wheel!
Sime is offline
post #8 of 9 Old 07-13-2007, 12:38 PM
Administrator
Red Rider's Avatar
Reputation Power: 47
Re: 95 front forks
If you're replacing the seals you want to check the forks to make sure you don't have any nicks or scratches...otherwise you'll be replacing them again before you know it.
Red Rider is offline
post #9 of 9 Old 07-13-2007, 12:42 PM Thread Starter
Quoted: 20 Post(s)
Re: 95 front forks
fork legs are fine just some small marks but have come off with autosol metal cleaner
jon 8214 is offline
95 900RR front fender BMW.Nick Honda FireBlade 7 05-26-2007 8:09 PM
WTB: 95 900 front fairing, stay,headlight mxprecidia Wanted 0 03-16-2007 7:00 PM
Will other model forks fit my 95 900RR? Mbjb00 Honda FireBlade 2 01-20-2007 9:32 AM
95 900RR loose front PAKETA_1 Honda FireBlade 2 06-07-2006 11:56 PM
Front forks ? Keith1K Honda FireBlade 1 10-02-2003 10:53 PM
