Wheel Bearings - Honda Motorcycles - FireBlades.org
post #1 of 18 Old 10-10-2003, 2:37 PM Thread Starter
Re: Wheel Bearings
Hey All -
I need to replace my wheel bearings. Where can I get new ones cheap? Need a set of rear wheel bearings and dustseals for a 1998 Superhawk rear wheel and the same for a 2002 CBR954 front..
Thanks!
BigTimmyRydesFast is offline
post #2 of 18 Old 10-10-2003, 2:45 PM Thread Starter
Re: Wheel Bearings
Also, does anyone have the part numbers?
post #3 of 18 Old 10-10-2003, 4:24 PM
Re: Wheel Bearings
ronayers.com would be my first choice
2OHOH2 is offline
post #4 of 18 Old 10-10-2003, 9:38 PM
Send a message via AIM to Aychdot Send a message via Yahoo to Aychdot
Re: Wheel Bearings
My bearings for the rear of my 929 were only about $10 each. I didn't buy dust seals. Bought them from Dave Mungenast Powersports in St Louis.
Aychdot is offline
post #5 of 18 Old 10-10-2003, 9:51 PM
NinerPilot's Avatar
Reputation Power: 25
Re: Wheel Bearings
Try ALL BALLZ bearings out of Parts Unlimited I think..... A set of 4 costs around the price of 1 Honda bearing.
Chris
NinerPilot is offline
post #6 of 18 Old 10-10-2003, 10:51 PM
Re: Wheel Bearings
Are you talking about aftermarket bearings? If you are, bearings aren't that expensive to begin with - seems like a very important part on which to save 2 or 3 bucks.
Bacchus is offline
post #7 of 18 Old 10-13-2003, 5:47 PM Thread Starter
Re: Wheel Bearings
Thanks everyone for the help!
For future reference the 929/954 front bearing part number (universal to any bearing shop) is 6005. And of course you want a sealed version. I know you guys wont care but the Superhawk rear rim is 6024uu or 6024rsr
post #8 of 18 Old 10-16-2003, 12:23 PM
Re: Wheel Bearings
How often do bearings need to be changed?
djice929 is offline
post #9 of 18 Old 10-16-2003, 2:10 PM
Re: Wheel Bearings
djice929 : How often do bearings need to be changed?
Whenever they are worn. Perform the tolerance check, located in the Service Manual, when changing tires and you will know when they are beginning to wear beyond allowed limits.
Kookie is offline
post #10 of 18 Old 10-17-2003, 1:07 PM
Re: Wheel Bearings
googolplexu : Quote (djice929 @ Oct. 16 2003, 11:23am)How often do bearings need to be changed?
Whenever they are worn. *Perform the tolerance check, located in the Service Manual, when changing tires and you will know when they are beginning to wear beyond allowed limits.
I checked with my mechanic and he says he does the check every time someone gets new tires, and i just did... duhhh.. i didnt even know they needed to be changed.. im more of a rider than a mechanic.
djice929 is offline
post #11 of 18 Old 11-10-2010, 3:35 AM
Send a message via Skype™ to SHiBBY
Re: Wheel Bearings
Any chance you know the size on the rear bearings for the 929 as well?
SHiBBY is offline
post #12 of 18 Old 11-10-2010, 5:28 AM
Reputation Power: 166
Re: Wheel Bearings
This thread is over 7 years old, I doubt any of the people who replied still use this forum!
Ronayers.com should be able to provide a part number, or do some eBay searching and see what type of bearings are offered for your bike. Bearings seem to have standard type codes from what I found, e.g. 6204 2RS (the 2RS means 2 rubber seals, from what I have seen).
If you can find the type you need, you can search for these bearings which may be cheaper than peope selling the same thing as 'motorcycle wheel bearings'. The bearing code is often found somewhere on the bearing itself, so you could also try looking at the bearings already in your wheel.
Dangerous Des is offline
post #13 of 18 Old 11-10-2010, 5:34 AM
Re: Wheel Bearings
Hehehe only saw that it was that old after I posted, sorry!
I spoke to the guys at Honda and they advised that I should just take the wheels off and tag the bearings along to our local bearing guru who sells new ones for like $3.00 (yea once converted it seems insignificant, but R25.00 is actually a pretty decent price over here!)
Thanks!
SHiBBY is offline
post #14 of 18 Old 11-10-2010, 6:56 AM
Re: Wheel Bearings
Thanks!
The fiche often includes bearing/seal dimensions or part numbers.
OEM Parts Honda CBR954RR (CBR900RR) 2000 REAR WHEEL - Cheap Cycle Parts
I agree though that it's always best to measure up the original bearings to be certain before ordering.
post #15 of 18 Old 11-13-2010, 7:15 AM
Re: Wheel Bearings
Right, The rear wheel uses 2x6005 on the hub and a 6205 on the crush drive/damper.
SHiBBY is offline
Funny noise in front wheel.. BushrodW Honda FireBlade 9 05-15-2009 2:23 PM
wheel chocks in your truck? Serial Thriller Towing / Transport 7 09-19-2003 9:36 PM
Wheel damage question lfg929 Honda FireBlade 2 07-18-2003 11:57 AM
Headstock bearings Proto Honda FireBlade 2 06-02-2003 12:46 PM
