954 rattle - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 08-18-2007, 9:01 PM Thread Starter
Send a message via AIM to Type Gendy
954 rattle
Ok, i know you guys have this too, hopefully somebody knows what it is. I had this weird rattle noise on both of my 954s at certain rpm / load ranges around 5-6k coming from the windshield/ headlight area. Never could really pinpoint what is making the noise. I have talked to other 954 owners who had the same problem. On my 03 it was partially my fender after removing the blinkers, but it was still there after puttin in rubber spackers. My '02 has it just as bad if not worse. It kills me cause its right where i usually like to ride in the rpm range.
ANY IDEAS??
Type Gendy is offline
post #2 of 8 Old 08-19-2007, 4:14 PM
Re: 954 rattle
It's probably the windshield itself against the edge of the fairing - lots of people have the same problem. I put some 1/4" wide self-adhesive foam strip around the edge of the fairing on mine, and then put the screen back in. Worked for a while , but started rattling again after about 6 months. Try gently tightening the screen screws (but careful not overtighten becaue they are just plastic).
TexasBlade is offline
post #3 of 8 Old 08-20-2007, 4:27 PM
Re: 954 rattle
there is rattle on my bike aswell around 5k rpm i tried to follow and it seems like its coming from under the gas tank. 02 954rr
peoples_champ is offline
post #4 of 8 Old 08-21-2007, 3:52 PM Thread Starter
Re: 954 rattle
NOt sure about the wind screen but i'll check it out next time i'm on it...
anybody else?
post #5 of 8 Old 08-21-2007, 5:45 PM
Re: 954 rattle
There is a number of cables in there and also you have the inside fairings that can push things around a bit when you take the sides off. Pull the front end off after removing the side fairings. Organize your wires, make sure they are going to the correct spots, make sure the gauges are mounted correctly, then put it all back together, and make sure every screw is in, and tight.
I bet if you do that your rattle will dissapear or you will figure it out, right quick.
x[corwyn] is offline
post #6 of 8 Old 08-21-2007, 9:06 PM
Re: 954 rattle
I'd check the CCT (cam chain tensioner) because its at around 5000 RPM that they usually rattle
Also I have a rattling front fender from a previous whoopsie
You dont happen to rides with a bunch of key at the headsotck either by any chance?
King Kenny is offline
post #7 of 8 Old 08-22-2007, 11:04 AM
Re: 954 rattle
I thought the same thing a few months ago since my bike is over 20k miles now. I went out and bought a Manual CCT to get that installed. I also bought a new upper fairing stay so I had to pull the whole front end apart to be able to get that accomplished. After I put everything back together the rattle was gone.
BUt yea the HTEV, CCT, chain, loose cable, keys, helmet strap hitting you on the side of the head.... you will need to work to eliminate which one of those it is.
post #8 of 8 Old 08-31-2007, 10:52 AM
Re: 954 rattle
its ur front end where ur headlight it, the upper stay on the 954s suck, mine rattles around too, another thing is ur windscreen, see if its hitting ur res on the handbrake, thats another reason mine was rattling, easy fix for me was to buy a stunt stay
allcagedup is offline
Flutter / rattle cornerblade Honda FireBlade 1 03-06-2007 1:03 AM
rattle from front on a 954 sscottab Honda FireBlade 5 04-18-2006 8:13 PM
954 ex-up rattle BladeRash Honda FireBlade 4 04-18-2006 5:47 PM
954 Engine Rattle forrest General Discussion 6 01-28-2006 10:47 PM
954 Windscreen Rattle Tank69 Honda FireBlade 27 09-10-2003 5:03 PM
