help please. - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 08-30-2007, 12:32 AM Thread Starter
Quoted: 2 Post(s)
help please.
ok heres the story. i washed my bike one day and the other the battery was dead so after checking all the conections i noticed that the connectors from the regulator were fried cuz of water, so i went to get a new regulator but i had to solder all the cables cuz the connector coming from the bike was fried to, but still no luck, the bike drained the battery and died, so i went to read the topics about charging issues and came across the diagnosis from a website, so the diagnosis was that (according to the website) I had soldered the wrong possitive cable. how can this happen? theres 4 cables coming from the RR (2 red and 2 green) same colors coming from the bike, so this two red cables need to go with their specific red ones on the bike or it does not metter? i also checked the cables comming from the stator and the manual says that it should not be continuity, so when i checked them the multimeter make a sound when touching the ground, this means there is continuity and the stator is gone? sorry for the long post. thanks
cbr_df is offline
post #2 of 4 Old 08-30-2007, 4:07 AM
Re: help please.
Which cable was fried? The one to the stator or to the harness?
It's always worth inspecting the stator at the same time. Your regulator may even have been okay. I had one that looked perfectly okay but was burned on the inside which was invisible until I removed it from the cover.
post #3 of 4 Old 08-30-2007, 10:19 AM Thread Starter
Quoted: 2 Post(s)
Re: help please.
i dont remember if the cables coming from the stator were fried, but the ones coming from the harness to the regulator were all busted, also while checking the cables coming from the stator i noticed that oil was inside this cables, is this normal? my diagnosis according to the website came out that i made a bad connection in the positive lead from regulator to battery, this means the 2 red cables coming from the regulator, how can this be possible if theres only two reds and two greens? theres no room for errors right?
cbr_df is offline
post #4 of 4 Old 08-30-2007, 1:29 PM
Re: help please.
I don't know if that's oil but mine were all sticky as well. I don't know what diagnosis you're talking about but I agree that'd it'd be pretty difficult to mistake them.
I think your reg was probably fine and your stator is fried instead.
Help Please Pookbe Honda SuperHawk 3 05-24-2007 9:48 PM
please help the angry goat Honda FireBlade 8 02-26-2007 2:15 PM
PLEASE HELP! roncbr900 Honda FireBlade 7 08-16-2005 1:18 PM
help please infostrata748 Honda FireBlade 4 07-25-2003 5:53 PM
Need Help, Please, Please, Please BushrodW Honda FireBlade 9 06-20-2003 4:24 PM
