one more problem please read - Honda Motorcycles - FireBlades.org
post #1 of 37 Old 09-01-2007, 9:25 PM Thread Starter
Quoted: 2 Post(s)
Broke down on the freeway and checked my mirror and I saw a lot of white smoke from the exhaust, pulled over and it just shuted down by itself. Any help will be nice.
cbr_df is offline
post #2 of 37 Old 09-01-2007, 9:42 PM
ozthis is offline
post #3 of 37 Old 09-01-2007, 9:59 PM
CBR929RE's Avatar
Reputation Power: 39
Re: one more problem please read
sounds like you blew the head gasket. check your coolant level and check your oil. if you're coolant is low and your oil looks milky its a head gasket.
CBR929RE is offline
post #4 of 37 Old 09-02-2007, 12:29 AM
Sounds like it. Isn't the white smoke indicitave of water in the combustion chamber.
Fisch is offline
post #5 of 37 Old 09-02-2007, 1:04 AM
CBR929RE's Avatar
if by water you mean coolant/anitfreeze then yes
CBR929RE is offline
post #6 of 37 Old 09-02-2007, 1:56 AM Thread Starter
Quoted: 2 Post(s)
im going to open the head and check the gasket, so i guess im going to replace it and check the valves while im at it. thanks guys.
btw i checked the coolant and it was low indeed, haven't checked the oil but i guess im going to find it milky right?
cbr_df is offline
post #7 of 37 Old 09-02-2007, 1:12 PM Thread Starter
Quoted: 2 Post(s)
i opoened the head and the gasket was ok (plastic one right?)also noticed that on the 3rd hole (whatever is called) where the throttle body goes to i can see two valves and they are flooded with gas, is this normal?
cbr_df is offline
post #8 of 37 Old 09-02-2007, 2:08 PM
CBR929RE's Avatar
what you checked is the valve cover gasket. thats not the problem. the gasket I suspect thats bad is the one between the head and cylinder block. you have to pull the motor to get the head off to replace that one. I suggest once you check the oil to see if its milky, take it to a shop if it is. its probably gonna be a good bill to fix it. the gasket I'm talking about is #3 here
I don't know what hole you're talking about. can you find it in the fiche
CBR929RE is offline
post #9 of 37 Old 09-02-2007, 2:47 PM Thread Starter
Quoted: 2 Post(s)
thanks for the info i guess i was looking at the wrong gasket. i'll pull off the upper part to check the gasket, i'll check the oil to see if its milky, if it is, what would you recommend, take it to the shop and let them rip my two eyes and a leg off or buy an engine from ebay?
cbr_df is offline
post #10 of 37 Old 09-02-2007, 9:36 PM
could have broken a ring, if you have fuel sitting on top of the valves you could have a bad fuel press reg which will make it appear to be smoking although it is actually raw fuel dumping out the pipe
kristribble is offline
post #11 of 37 Old 09-02-2007, 10:07 PM Thread Starter
Quoted: 2 Post(s)
yeah that what i saw, i looked at the "holes" and i saw two valves and they were like half full of gas. the valves are upside down like the flat side facing down i just saw two of them in the 3rd "hole" half full of gas, the other holes 1,2,4, look ok no gas on them. so the pressure regulator is the thing at the end of the fuel rail right? the raw fuel dumping thing could have been the reason for engine shut off?
cbr_df is offline
post #12 of 37 Old 09-02-2007, 11:21 PM
You will be a lucky man if it is just a FPR. They are only about $70. Is there a sure fire way to check the FPR? Remove and just suck through it from small to big not from big to small.
Fisch is offline
post #13 of 37 Old 09-02-2007, 11:41 PM Thread Starter
Quoted: 2 Post(s)
i sucked the dam thing and could not get any air. is it busted?
cbr_df is offline
post #14 of 37 Old 09-03-2007, 8:27 AM
Have you looked at the oil yet? Don't go looking for other small problems without trying to eliminate the main ones first.
Also, if you don't know what the "holes" are, I'm not sure I would reccomend trying to redo the headgasket yourself. It's a fairly major job. Ebay engine might be a better option.
playwme is offline
post #15 of 37 Old 09-03-2007, 8:47 AM
this is what i thought, too. tons of blow-by manifest itself like grey/white smoke. but, check your oil first!
Ol' Gravy Leg is offline
954 problems....Please read. 2002cbr954 Honda FireBlade 14 04-22-2007 7:00 PM
Spoilers *** Please Read Me*** NinerPilot Road Racing: Professional 2 03-11-2005 1:46 AM
One more JACKASS to read about Tank69 Honda FireBlade 48 08-11-2003 11:35 AM
