head removal....... - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 09-06-2007, 9:02 PM Thread Starter
head removal.......
in a previous post yesterday i had a loud clunking in my motor soundin like marbles. 954 broke at track.
well after checkin the cct, i noticed that three of my cylinders are workin properly and one is not, i have fuel and fire to all cylinders but the one to the farthest right isnt heating up. i will have to check the compression
but i know the motors jumped timing. so thats why i think it might have bent a valve in that ylinder thats not heating up. can you remove the head with the motor on the bike or do you need to drop the motor to pull the head...? thanks
Rollfactor is offline
post #2 of 6 Old 09-07-2007, 1:39 AM
Re: head removal.......
You can confirm a bent valve without removing the head.
Measure your valve clearances and do a wet and dry compression test.
post #3 of 6 Old 09-07-2007, 2:23 AM Thread Starter
gotcha.... now as for the wet and dry comp test... how you perform one over the other?
post #4 of 6 Old 09-07-2007, 2:28 AM
Check compression first, then put a few cc's of oil in the cylinder and check it again. No difference means a valve is leaking (too big a gap for the oil to seal). If it increases it means a ring is bad (small gap sealed as oil bypasses it).
post #5 of 6 Old 09-07-2007, 3:18 AM Thread Starter
so what kinda readings should i get when i do the wet compared to the dry showing valves and rings are all good and sealing properly??
post #6 of 6 Old 09-07-2007, 3:24 AM
If rings and valves are both good there should be very little difference between wet and dry readings.
Good place to get head bearings (fork head) Firehawk Honda FireBlade 9 03-02-2007 6:33 PM
Sticker Removal 2 maxredline Honda FireBlade 14 09-18-2006 4:22 PM
PS2 Head To Head? Baketech Off-Topic 5 12-18-2005 2:46 PM
954 Head vs. 929 Head victoRR Honda FireBlade 1 09-15-2004 1:36 PM
Head removal advice please BlueToy Honda FireBlade 14 07-18-2003 11:38 AM
