954 wont start - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 10-21-2007, 12:28 PM Thread Starter
954 wont start
Hi,
I have a 954 which has been getting more and more difficult to start. For the first few attempts its as if there's no fuel being sent at all. Then after a few more one of the cylinders starts to cough and splutter. A few more again and two or three cylinders splutter and if I'm lucky after that, the engine starts and everything is fine. When its mis-behaved like this it generally starts ok (first or second press of the button) the next day.
Today I tried to start it after the bike has stood for three weeks and no joy. I ran the battery down trying to start the bike for about ten minutes. I then used jump-leads from my car but still failed to get the engine going. I never got past the "one cylinder occasionally coughing and spluttering" phase.
The fuel's young, the spark is good. I've read elsewhere on this forum that a diaphragm in the fuel pressure regulator might be the problem. Is there anyway I can check? Is it an easy/cheap job to change the regulator?
Cheers
Dave
jump-jet is offline
post #2 of 4 Old 10-24-2007, 7:22 PM
Re: 954 wont start
If it was the fuel reg it would not run right anytime. It kinda sounds like a vacuum leak in the fuel system. If you have a vacuum leak the fuel would not stay pressurized and you would have to wait for it to reach enough pressure to fire. One way to test this theory is to turn the ignition on and off several times to allow the fuel pump to build pressure before you try to start it. If it starts the check fuel system( fuel rail, injector seats, hoses) for a leak.
kristribble is offline
post #3 of 4 Old 10-25-2007, 6:53 AM Thread Starter
Re: 954 wont start
Its beaten me. The dealer is looking at it now...
jump-jet is offline
post #4 of 4 Old 10-26-2007, 2:20 PM
Re: 954 wont start
I would have started by replacing the plugs, then checked for trouble codes stored.
Jfriday is offline
honda 954 wont start? camo954 Honda FireBlade 9 06-18-2007 1:25 AM
954 wont start... 2002cbr954 Honda FireBlade 19 04-27-2007 12:12 PM
954 wont start bryanclapper69 Honda FireBlade 2 03-18-2007 6:11 PM
954 wont start.. cant do all tests.. chkaotic Honda FireBlade 3 03-06-2006 9:23 AM
2002 Honda 954 wont start sideshow General Discussion 8 11-18-2004 1:41 PM
