929 PROBLEM? - Honda Motorcycles - FireBlades.org
post #1 of 27 Old 10-21-2003, 5:20 AM Thread Starter
Re: 929 PROBLEM?
HI ALL,
READ, CBR 629 (12 OCT 03) PROBLEM, AND ALL THE HELP HE RECIEVED...
WONDER IF YOU CAN DO THE SAME 4 ME.
WENT OUT TO START MY 929 THE OTHER DAY, *GOT RED LIGHT, FUEL PUMP AND ALL THE NORMAL START UP REQUIREMENTS, APART FROM A LOUD CLICKING NOISE FROM UNDER THE SEAT. ENGINE DOESN'T *TURN OVER, JUST THIS CLICKING.
USING THE HONDA MANUAL I VE NARROWED IT DOWN TO THE MAGNETIC SWITCH.
ANY ADVICE, APART FROM SEEING A BLADE DOCTOR?
THANKS
GAZZERUK is offline
post #2 of 27 Old 10-21-2003, 7:10 AM
Re: 929 PROBLEM?
Might be that the battery does not have enough charge. I'd try that first since it's easy to do.
Jeremy Lucas
(00 929 R/W)
(00 Muzzy ZRX)
(00 929 Y/B)
(97 VFR750)
(89 FZR400)
lateapex is offline
post #3 of 27 Old 10-21-2003, 7:22 AM
ND4SPD's Avatar
Reputation Power: 50
Re: 929 PROBLEM?
That's your starter clicking. The battery is too weak to turn it.
ND4SPD is offline
post #4 of 27 Old 10-21-2003, 7:46 AM Thread Starter
Re: 929 PROBLEM?
ND4SPDSHO : That's your starter clicking. *The battery is too weak to turn it.
Thanks somebody @ work said the very same...
I'll get the jump leads out this weekend.
GAZZERUK is offline
post #5 of 27 Old 10-21-2003, 7:48 AM Thread Starter
Re: 929 PROBLEM?
lateapex : Might be that the battery does not have enough charge. *I'd try that first since it's easy to do.
Thanks...
Looks like you may be right....
GAZZERUK is offline
post #6 of 27 Old 10-22-2003, 2:54 PM
Re: 929 PROBLEM?
flat battery
ive been told not to use jumpleads on the injected bikes ...take the battery off and charge it instead to be safe
jonnyboy is offline
post #7 of 27 Old 10-22-2003, 3:32 PM
Re: 929 PROBLEM?
I have jumped my 929 and RC51 from my Suburban dozens of times without any problem. The 'jumper warning' is an urban legend myth . . .
abtech is offline
post #8 of 27 Old 10-22-2003, 6:52 PM
BushrodW's Avatar
Send a message via Yahoo to BushrodW
Re: 929 PROBLEM?
GAZZERUK : HI ALL,
THANKS
buy new battery time, I'd guess.
www.AirAmericaRadio.com
BushrodW is offline
post #9 of 27 Old 10-24-2003, 7:11 AM Thread Starter
Re: 929 PROBLEM?
jonnyboy : flat battery
Gonna use OPTIMATE trickle charger.......
Cheers.....
GAZZERUK is offline
post #10 of 27 Old 10-24-2003, 7:13 AM Thread Starter
Re: 929 PROBLEM?
BushrodW : Quote (GAZZERUK @ Oct. 21 2003, 1:20am)HI ALL,
THANKS
Hope not!
GAZZERUK is offline
post #11 of 27 Old 10-24-2003, 7:20 PM
Zeeman's Avatar
Quoted: 4 Post(s)
Reputation Power: 22
Re: 929 PROBLEM?
Why not just push start it? There should be enough juice in the battery to get the thing running if the engine is kicked over externally...
Z...
You're f%#&king up my Chi...
Zeeman is offline
post #12 of 27 Old 10-24-2003, 7:37 PM Thread Starter
Re: 929 PROBLEM?
Zeeman : Why not just push start it? There should be enough juice in the battery to get the thing running if the engine is kicked over externally...
Z...
Tried it in 4th, down slight incline, nothing...
Since then I started it with jump leads....
'ABTEC' UWER RIGHT...
Thanks 2 everyone who replied.
GAZZERUK is offline
post #13 of 27 Old 10-24-2003, 7:39 PM
Re: 929 PROBLEM?
told ya . . .
abtech is offline
post #14 of 27 Old 10-24-2003, 7:50 PM
Re: 929 PROBLEM?
The secret to jump starting a motorcycle from a car's battery is simple. Make sure the car isn't running.
The amperage (strength of current) on a car is greater than that of a m/c and will fry your shizzle.
Carry on.
Voodoo954 is offline
post #15 of 27 Old 10-24-2003, 7:55 PM
Re: 929 PROBLEM?
Not a bad idea to leave the car off, but there are a hell of a lot of different amperage ratings on cars and trucks...and some (like my Mustang) probably aren't far off a bike.
luvtolean is offline
929 forks fit on a 954??? synrrgy Honda FireBlade 4 12-01-2003 8:27 PM
929 running problem mjaques Honda FireBlade 6 09-06-2003 2:29 PM
