chainging front brake discs - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 01-30-2008, 11:52 AM Thread Starter
spp
My brake discs on my 954 are warped and need replacing. How difficult is this to do. I suspect it's as simple as just taking the front wheel off? Any hidden difficulties associated with this?
spp is offline
post #2 of 4 Old 01-30-2008, 12:07 PM
sheepofblue's Avatar
Reputation Power: 48
Re: chainging front brake discs
Very easy. Take the wheel off and use an allen head wrench. I recommend torquing the them on reassembly but at a minimum use loctite on the bolts.
Must obey the sheep dog
sheepofblue is offline
post #3 of 4 Old 01-30-2008, 5:53 PM
Reputation Power: 21
when i took mine off and put them on again i bolted them on the same way you'd do a car tire ( bolting one, then the opposite side, and working your way around). i did it that way just as a precaution.
MACI4LIFE is offline
post #4 of 4 Old 01-30-2008, 11:32 PM
Deffinitely a good idea to tighten the mounting bolts in a star pattern. Loc tite is also a good idea. I had my bolts back off right after I first got my bike, not a good feeling. It would be best to use blue loc tite, not the red. The red is a bit extreme and may make the bolts too difficult to remove next time. The blue us one step down from the red, and plenty strong enough. Not a mechanic, just putting in my two cents. This is just my humble opinion.
Ace57988 is offline
Front Brake Noise SORTAFAST Honda FireBlade 10 08-18-2012 10:19 PM
Brake Discs Jezzder Honda FireBlade 5 01-05-2008 6:47 AM
98 rrw brake discs question... lickshot Honda FireBlade 12 08-20-2007 10:46 AM
Cast iron front brake discs on 929? rvfbill Honda FireBlade 0 07-26-2005 8:24 PM
Brake Discs jarv6969 Honda FireBlade 0 03-23-2005 6:50 PM
