the worst engineered bike ever - Honda Motorcycles - FireBlades.org
post #1 of 80 Old 10-29-2003, 11:27 PM Thread Starter
Re: the worst engineered bike ever
This bike is by far the worst designed bike ever.
I simply started off going to change the air filter and spark plugs. Some of you can already see where this is going and can stop reading here.
Design Flaw number 1) - gas tank design - where the f&8k is the d#(n petcock? The 'vacuum system' doesn't work - period. I followed the FSM to a T and now have about 2 gallons of gas on my garage floor. How hard is it to put a petcock on the tank? How much can that really add to the cost of a bike?
Design Flaw number 2) - spark plug location - on a 'maintenace' item, why would you ever locate it where you couldn't get to it? I followed the service manual exactly, and there is no way that I can get any tools in there to get to the spark plugs. I have removed almost the entire front of the bike already (only left the forks). Looks like I have no choice but to remove the whole top end of the bike also. How hard is it to design a way to get to a maintence item?
This is my first Honda product - ever. It will definately be my last - ever. If I did this type of shoddy design work, I'd be homeless.
DavidGS is offline
post #2 of 80 Old 10-29-2003, 11:32 PM
sell it before it needs any more maintainence.
Insignificant Member
freq is offline
post #3 of 80 Old 10-29-2003, 11:36 PM
Dude... I'll try not to rag on you too much for such blasphemy, m'kay?
Worst?
OK, tell you what. Less than two hours ago I talked to a guy who had his Ducati 998 serviced. The 6,000 mile service cost him $1800, much of which required special tools (in other words, not something doable by you or me). The valve adjustment alone takes about four hours. The plugs are just as buried within that bike as the 929/954/damn-near-every-other-modern-sportbike.
So you spilled some gas (operator error), and weren't happy with the spark plug placement (a Harley, perhaps?). Does that about cover it?
2OHOH2 is offline
post #4 of 80 Old 10-29-2003, 11:36 PM
Yeah. Honda engineers are well know to be the worst in the world.
Neither item you listed is a design flaw in any way.
#1) You don't need to remove the tank to change the air filter or the spark plugs.
#2) If you can't change the spark plugs or air filter without making a mess and blaming the bike design, you're a moron.
I hope you never buy a Honda again. Buying something else will force you to learn how to work on a bike.
Go troll somewhere else.
BDA116 is offline
post #5 of 80 Old 10-29-2003, 11:39 PM Thread Starter
I work with sportbikes all the time, and none of the Yamaha's, Kawasaki's, or Suzuki's have been this bad. I'm dreading tearing apart the two 600RR's at the shop if they are at all similar.
Basic maintenance items should not be time-consuming to do.
DavidGS is offline
post #6 of 80 Old 10-29-2003, 11:43 PM
I hate to admit it but everyone here that just ragged on you is right, why would you want to come to a forum that is pro honda 929ers and discrace it. Maybe you should design a bike that suits your needs.
cheers
mark
MarkN929RR is offline
post #7 of 80 Old 10-30-2003, 12:12 AM
Right on Mark! I have not any trouble working on my bike or my buddys 929. I changed the plugs simply by removing a few fairings. I even used the sparkplug tool that comes with the bike. Maybe he should check into MMI!
roadracer319 is offline
post #8 of 80 Old 10-30-2003, 12:44 AM
TCD
i never had a problem changing the plugs on mine...
TCD is offline
post #9 of 80 Old 10-30-2003, 12:46 AM
Well, DavidGS, you have been a member for *4 months and have 44 posts. *So you are not exactly new to this forum. *It is the price you pay for compact, lightweight sportbikes. *Sooooo, I guess, what is your point?!
edit: *removed a mistake *
Bacchus is offline
post #10 of 80 Old 10-30-2003, 2:07 AM
DavidGS : I work with sportbikes all the time, and none of the Yamaha's, Kawasaki's, or Suzuki's have been this bad. I'm dreading tearing apart the two 600RR's at the shop if they are at all similar.
Are you implying that you're a professional service technician?
If so, please understand that you are the reason I do all my own work on my bike, and no shop will ever touch it. If you're not a professional mechanic, my appologies. This forum is here to assist you. If you did a search here before you started emptying the gas tank you could have prevented the mess and saved some time.
Joel is offline
post #11 of 80 Old 10-30-2003, 2:18 AM
2OHOH2954 : OK, tell you what. Less than two hours ago I talked to a guy who had his Ducati 998 serviced. The 6,000 mile service cost him $1800, much of which required special tools (in other words, not something doable by you or me). The valve adjustment alone takes about four hours. The plugs are just as buried within that bike as the 929/954/damn-near-every-other-modern-sportbike.
Holy crap! I hope those were Jamaican dollars!!!! Bahahahahahah someone saw your pal coming a mile away.
My 6000k service cost me $85 in labor and less than $100 in parts (and special tools&#33.
The 12k service is more pricy since you need $160 in belts plus the labor (a few hours) to R&R them and re-set timing.
At any rate.. I can relate to the crappy 929 design. How many FREAKING different fasteners can they pull out of thier asses to use on a bike.
In contrast.
Honda 929
oil filter right up behind the headers - stupid
plugs in an area so tight you need a wrench (not a ratchet) to extract them (thankully Honda provides the required tools)
Fairings that take over an hour to R&R
998
takes 5 min totally strip bike (includint tank which comes from the factory with quick-disoneects that don't leak)
10 Dzus fasteners and all lower bodywork off (takes less than 60 secons)
oil fiter on bottom of engine in very easy to access possition, any number of tools can be used toextract it (unlike on the 929)
Plugs are nore a 'breeze' but remove fairings, move aside one oil coller and more aside tank. Everything accesable.
Air filters (are reusable foam like UNI's) are a pain (about 8 small screws per side to get at them inthe ram ducts).
There are ups and downs on each bike. 929 goes 16k miles between major services, that's pretty sweet. Too bad it's a major pain to work on.
I felt your pain (until I sold the 929).
$1800 for 6k services. Tell him to bring it to my place and I'll do it for 1/2 next time!
Oh, and the plugs maybe as 'burried' but they onlt take about 5 min. to get too an remove AND you can use commone ratchet tools to remove them.
Work on one some time. I used to think the Japanese were good at engineering stuff for service (comparted to American companites) until I worked on my Duc.
As always, YMMV!
Holeshot is offline
post #12 of 80 Old 10-30-2003, 2:28 AM
Holeshot : Holy crap! *I hope those were Jamaican dollars!!!! *Bahahahahahah *someone saw your pal coming a mile away.
No kidding. Dunno what happened there, but he got robbed. Told me that was the last time that he'll ever take his bike there. Ya think?
Maybe I should get the details. For amusement purposes only
2OHOH2 is offline
post #13 of 80 Old 10-30-2003, 3:09 AM
First of all, how many fuel-injected bikes have you seen with a petcock? Pretty hard to put one on there when the pump is in the tank. Duh.
And how could it be any easier to change the oil filter? You just use a pair of Channel locks and go in through the hole in the right side fairing. No need to even remove any plastic. Or get a K&N filter with the nut on the end and just use a ratchet.
As far as changing the spark plugs and air filter, all you have to do is lift up the front of your tank and tie it to the rear bungee hooks to hold it. No need to remove any hoses or spill any gas. And Honda gives you the spark plug socket, even. What more do you want?
Don't blame the bike for your ineptitude.
OldFatGuy is offline
post #14 of 80 Old 10-30-2003, 3:18 AM
vma
Yo dude, get a new XR50R. Spark plug on this baby, well, you know what I´m talking about...
vma is offline
post #15 of 80 Old 10-30-2003, 4:12 AM
Mattress's Avatar
Reputation Power: 19
Better yet, get a bicycle, then you'll be happy, nothing buried at all
Mattress is offline
RC51 v RC51 v CBR954RR v CBR600RR ccwilli3 Honda FireBlade 53 08-08-2010 4:28 PM
Sold the bike Stretch Honda FireBlade 15 11-17-2003 2:31 PM
Younger Oil Racing 2003 tigerblade Road Racing: Club / Amateur 1 10-07-2003 2:15 PM
damage bike pics Mojave954 Off-Topic 11 07-24-2003 11:48 AM
