2008 Fireblade Transmission - Honda Motorcycles - FireBlades.org
post #1 of 25 Old 03-30-2008, 1:37 PM Thread Starter
Reputation Power: 41
I am still getting used to my new Fireblade after a v-twin.
I find the throttle repsonse very smooth, but when throttling off quickly I find the transmission on my bike quite noisy. I was wondering if my chain needed adjusting, or is the Honda transmission noisy normally ? I only notice it on throttling off, not an overly pleasant sound. I hear it too if you are riding on a bumpy road where the bumps may make you throttle off unintentionally. Kind of a difficult sound to explain, almost clunky I suppose.
I thought I would ask you guys if this is normal before I asked my dealer.
splatty is offline
post #2 of 25 Old 03-30-2008, 1:56 PM
Re: 2008 Fireblade Transmission
What kind of clunking sound is it? Is it a per-clunk, clunk, thunk, clack, or ca-chunk? You got to know your clunks!
dattaway is offline
post #3 of 25 Old 03-30-2008, 2:14 PM Thread Starter
Not great at explaining clunks !!
Sort of reminds me of a sound you might get with too much chain slack.
Funnily enough the sticker on the swingarm says 35mm of chain play. When you move the chain to check for slack, 35mm takes it too the bottom of the swingarm but it does seem within tolerance.
It may well be normal as I suppose you will always get tranny noise if you just shut the throttle on any bike. On my Aprilia with twin Akrapovics I coudln't here anyhting though !!
Hopefully somebody with an 08 will confirm this.
splatty is offline
post #4 of 25 Old 03-30-2008, 2:57 PM
Is it one single "clunk"? If it is I've noticed it too. This is my first Honda, so I figured it was the nature of the beast.
Torch is offline
post #5 of 25 Old 03-30-2008, 3:35 PM
I'm not an expert by any stretch of the imagination, but I have owned 3 Hondas. My 08 1000 is a little nosier that than the 954 or my 600 F4i when shifting. If your shifting down to 1st, I'm almost 99% sure it's totally normal.
8-Ball is offline
post #6 of 25 Old 03-30-2008, 3:54 PM
soon2b954's Avatar
Yes, Honda's are notorious for the neutral into first clunk, other then that Honda transmissions are fairly smooth shifting between gears.
Look, lean, believe!!
soon2b954 is offline
post #7 of 25 Old 03-30-2008, 4:33 PM Thread Starter
Yes mate, although I'm not sure "clunk" is the best description, but I gather you know what I mean.
I would say it is almost like it is the front sprocket spinning a bit to take up the slack in the chain. Maybe something to do with the slipper clutch ?? Who knows, but I am sure it's just a characteristic of the bike.
splatty is offline
post #8 of 25 Old 03-30-2008, 4:34 PM Thread Starter
No shifting mate, just throttle shut off, probably not smoothly shut off either !!
And yes, mine makes a lovely clunk in to first. I expected that.
splatty is offline
post #9 of 25 Old 03-30-2008, 5:54 PM
haven't noticed anything clunking when throttling off.
only thing i've notices is that occasional crick in the clutch lever pull due to the slipper clutch (which has been discussed as normal).
rbiker is offline
post #10 of 25 Old 08-01-2008, 6:32 PM
its normal what you are hearing, enjoy the bike and be happy nobody is found in your mirrors
ton304 is offline
post #11 of 25 Old 08-02-2008, 12:36 PM
Reputation Power: 15
Dont worry m8y,mines the same .
Stu748R is offline
post #12 of 25 Old 08-03-2008, 4:32 PM
Reputation Power: 12
Splatty
do you mean the super charged kind of whine when you throttle off loudest in 2nd?
if so its normal although my 1st 08 did it to the extreme and suffered a gear box failure!!!!
Rich22 is offline
post #13 of 25 Old 08-04-2008, 4:43 AM Thread Starter
Nah mate........just a box characteristic me thinks.
Mine only makes a super-charger whine in second when I am throttling hard and she is trying to pull my arms off
splatty is offline
post #14 of 25 Old 08-04-2008, 8:47 AM
Splatty, I'm a first timer on a Blade (mines the '08 too) after having always had v-twins and I've had the same feeling. It feels like the chain takes up a load of slack when you throttle off, which is what I always thought was happening.
I had a Buell before this so it never had any chain slack stuff... however, it also never had any of the other things that make the blade so amazing to ride!
stubobaloo is offline
post #15 of 25 Old 08-23-2008, 1:32 AM
hey what about when your comming to a stop without down shifting, ie just pull in the clutch lever, and when your stopped you have troble clicking down all gears , and wont click down to 1st unless you slightly let out the clutch
gotama is offline
2008 Fireblade .OrgOwner Honda FireBlade 596 08-19-2012 6:39 PM
2008 Fireblade Transmission splatty Honda FireBlade 3 03-30-2008 2:08 PM
2008 Fireblade on eBay denzee Honda FireBlade 9 03-17-2008 9:23 PM
2008 Fireblade Ugly? smilertiv Honda FireBlade 101 02-26-2008 12:07 PM
2008 Fireblade modeled after 2008 RCV 212 Motodude General Discussion 0 11-07-2007 10:37 AM
