2002 954 no start when hot - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 03-30-2008, 5:13 PM Thread Starter
I've got a 2002 Honda 954 last 2 days it seems if i ride for a coupple of hours and park the bike it wont restart. Both days the outside temp was near 90. If i let it sit for an hour or so it starts right up. When riding theres no lack of power or anything funny. I just got this bike 3months ago, its got a PCIII and a micron full system on it. Its happened 2x, and both time i had nothing with me to determine if its fuel or ignition related. The fuel pump was running when the problem occurred.
Any ideas? Is there anything i can check, or any sort of common problem?
thank you.
chris02954 is offline
post #2 of 4 Old 03-30-2008, 5:18 PM
Reputation Power: 59
Re: 2002 954 no start when hot
Does that mean the pump was running constantly?
Twincam is offline
post #3 of 4 Old 03-30-2008, 8:00 PM Thread Starter
turn key pump turns on, and then turns off, operating normal
post #4 of 4 Old 03-31-2008, 12:47 AM
Reputation Power: 12
If too much heat is being transfered to the intake air temp. sensor it gets heat soaked. When you shut the bike off there is no moving air coming across it. this causes the bike to think it's plus lots outside and the fuel curve is leaned so much it won't fire. This happens to mine but I'm running an aluminum intake mahifold, so on shutdown there's a lot of heat energy to transfer. It's an idea . The coolant temp sensor will also cause a lean hence horrid starting condition but there is lots of coolant to dissipate the heat so I doubt this is the problem.
squeeze is offline
Sabre that won't start when engine is hot hesterjs General Discussion 5 04-30-2007 2:59 PM
954 2002 won't start 02ride954 General Discussion 12 02-02-2007 4:09 PM
929 No start, no fuel, no spark, help please Jackelauto Honda FireBlade 11 10-26-2006 12:47 AM
Tough to start 2002 954, at random thelemur Honda FireBlade 10 07-10-2005 8:58 PM
2002 Honda 954 wont start sideshow General Discussion 8 11-18-2004 1:41 PM
