Reputation Power:
31
Re: Winterization
I change the oil and filter. Then I add stabil to the gas and run it for about 10-15 mins to circulated the 'stabilized' gas throughout the system. I remove the battery and bring it inside and trickle charge it overnight about once a month. I put tin foil over the exhaust can, clean it up, and throw a sheet over it. Then I dream about Spring and the returning warm weather!
I personally don't subscribe to the 'start it up and run it once a week' philosophy. I don't trust that all the condensation will be burned off in a 20 min. run. It's really just as easy to bring the battery inside. I used to put oil in the spark plug openings when I had a parallel twin where they were easily accessible. I don't do that now.
