Finally Got the Blade Out The Garage - Honda Motorcycles - FireBlades.org
post #1 of 2 Old 04-18-2008, 4:46 AM Thread Starter
Reputation Power: 41
Finally. It was dry yesterday afternoon and I managed to go and put 100 miles on the new toy. Really enjoyed it as I am still getting used to sportsbikes again. Wrists still ache a bit after a naked, but I'll get there. So easy to gain cornering confidence on this tool. I have to report I am running standard pressures in the BT015s and all is good ( just been reading the tyre thread ).
Spending a sunny afternoon getting acquainted with your new two wheeled love is a great way to pass a couple of hours.
The only problem I had yesterday was changing from 5th to 6th a couple of times when I didn't engage 6th properly. I am putting this down to me getting used to the bike, and it still only having 250 miles on the clock. My Aprilia had a false neutral at first between 5th and 6th if you weren't firm enough with the change. Any record of this on new Honda gearboxes or is it just me ?
I hope to get 600 miles on asap and get the first service done so I can stop watching the revs !! After the gear change experiences I checked the chain. Seems a lot of play, even though it is in tolerance to what the sticker says. Strange it says 35mm of play when if you push the chain up 35mm it will reach the swingarm before you can measure it ?
splatty is offline
post #2 of 2 Old 04-18-2008, 10:39 AM
Re: Finally Got the Blade Out The Garage
yo splatty yep weather has been better down south as well nearly run mine in as for the gear changing i was having trouble down changing and then the final click into first ie at traffic lights. it doesn't do it all the time though i did tighten the clutch one full turn so could have been the cable bedding in maybe?
my chain got really loose after about 150 miles mate took it back to the dealership and they adjusted it and i can tell you there isn't 35mm of play in it! come to think of it gears have been a lot better since i had that done could be it mate?
dev435 is offline
Finally sold the 954....check out the new bike! bigzantt Suzuki Motorcycles 29 05-28-2008 3:40 PM
Finally got out on the track - some thoughts about the CORE trackday at Grattan 5-20 CBRVFR Track Days / Riding Schools 16 06-30-2006 2:04 PM
Cleaned out the garage. Nillotuc Off-Topic 9 06-02-2004 9:13 AM
Been out in the garage, slappin... Chain Riding Gear / Luggage 8 04-02-2004 6:00 PM
Got the blade on the dyno (finally) kirby Honda FireBlade 12 06-30-2003 8:25 AM
