954 big bore kits? - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 10-30-2003, 8:08 PM Thread Starter
Re: 954 big bore kits?
Anyone bought/installed a big bore kit on a 954? I know Wiseco has one 1mm over. Any information/feedback on big bore kits on a 54 is greatly appreciated!!!!
02FBlade is offline
post #2 of 10 Old 10-31-2003, 2:11 AM
Jungleboy's Avatar
Try this link
Link
2004 1000RR Racebike
www.jungleboyracing.com
Jungleboy is offline
post #3 of 10 Old 10-31-2003, 2:24 AM
Jungleboy's Avatar
The above link is relating to a 929 but they both have the same stroke (54mm) just the 929 has a 74mm bore and the 954 has a 75mm bore therefore with the 76mm big bore kit you are refering to they both end up at 980cc, the only other point although the 954 has 1mm bigger pistons they are actually lighter than the 929 pistons as they have a smaller skirt than the 929(more of a slipper design) , so im not sure how the aftermarket pistons compare to these, maybe if you shop around you can find the lightest set?
post #4 of 10 Old 10-31-2003, 8:57 AM
You could always purchase something with a thousand cc's to begin with and not have to worry about boring and such.
Btw, that's a damned funny avatar!
Chain is offline
post #5 of 10 Old 10-31-2003, 9:48 AM
Chain : You could always purchase something with a thousand cc's to begin with and not have to worry about boring and such.
this coming from a guy that owns a sewing machine for a motorcycle... 'D
ccwilli3 is offline
post #6 of 10 Old 10-31-2003, 1:06 PM
ccwilli3 : Quote (Chain @ Oct. 31 2003, 7:57am)You could always purchase something with a thousand cc's to begin with and not have to worry about boring and such.
IMO, a twin or triple will always outscore an inline four in the character department. That said, have you ever heard Yamaha's 20-valve R1 motor spin up? It's got a certain burble that, while not exactly exotic, sure sounds better than my generic sounding 954's mill. Seriously, they really DO sound different than 4-valve per cylinder machines. Pretty cool actually.
Chain is offline
post #7 of 10 Old 10-31-2003, 1:30 PM
tigerblade's Avatar
Reputation Power: 32
Chain : That said, have you ever heard Yamaha's 20-valve R1 motor spin up? It's got a certain burble that, while not exactly exotic, sure sounds better than my generic sounding 954's mill. Seriously, they really DO sound different than 4-valve per cylinder machines. Pretty cool actually.
There's a term for your statements, Chain. It's called 'cognitive dissonance'.
Is a paradigm worth 20 cents?
tigerblade is offline
post #8 of 10 Old 10-31-2003, 2:18 PM
tigerblade : There's a term for your statements, Chain. *It's called 'cognitive dissonance'. *
Perhaps.
I was only trying to keep from busting out my new signature emoticon ( ) and reply in a more intellectual manner instead.
Chain is offline
post #9 of 10 Old 10-31-2003, 4:49 PM
Chain : Quote (ccwilli3 @ Oct. 31 2003, 8:48am)Quote (Chain @ Oct. 31 2003, 7:57am)You could always purchase something with a thousand cc's to begin with and not have to worry about boring and such.
Have you heard a 929/954 with a snappy race fuel map, exhaust, CAI and cams? I assure you, it gets your attention.
Of course, IMO, sound is a very personal thing. The higher the revs the better, so, twins and triples don't do it for me. The R6 on the other hand...
luvtolean is offline
post #10 of 10 Old 10-31-2003, 7:15 PM
As Jungleboy already showed (link above), I bored my 929 out and am very happy with the results. It would have very similar results as others have stated the 954 is pretty much the same motor. On my bike, I have the 954 throttlebodies/injectors as well. Definately a good 'bang for the buck' if you're doing the labor yourself.
Jake is offline
954 shock for 929?, other "better" OEM? 2bitsamile Honda FireBlade 2 12-01-2003 8:36 PM
954 fork spring rate Proto Honda FireBlade 11 08-05-2003 8:12 PM
Dyno'd the 954 K9inAZ Honda FireBlade 9 07-19-2003 3:57 AM
performance parts for the 954 gb506 Honda FireBlade 1 07-10-2003 12:59 PM
