Suspension setup - Honda Motorcycles - FireBlades.org
post #1 of 2 Old 11-01-2003, 7:12 PM Thread Starter
Re: Suspension setup
How do you have yours setup?
My bike has about 14k miles on it and I don't know if the seals or fluid have ever been replaced. I think it's about that time, but till then....what's your setup?
I am about 190-200lbs., I have 2 full turns from hard on the rebound, compression the same, 3 lines showing at the top (I doubt this makes any sense to suspension guys since I don't know much about it anyway).
Any ideas? Insight?
victoRR is offline
post #2 of 2 Old 11-01-2003, 11:55 PM
From the abtech archive:
For suspension settings at 190 lbs (unsuited???), I would crank the front preload in all the way, and set both compression and rebound to 1.5 turns out from full tight (clockwise to the stops and then back out 1.5 turns).
I would then take out all of the rear preload except 1 click, and set both the compression and rebound to 1.75 turns in from fully open (CCW all the way to the stops and then CW 1.75 turns).
This should be a decent starting point.
jafo is offline
Track setup...when tires get worn 02FBlade Honda FireBlade 2 10-02-2003 7:25 PM
suspension settings again erionone Honda FireBlade 4 09-10-2003 1:00 AM
friend in dire need of rc51 setup baselines risc32 Honda FireBlade 4 08-26-2003 4:31 PM
954 suspension website? gerry Honda FireBlade 1 07-18-2003 10:20 PM
rear suspension help half Honda FireBlade 13 06-16-2003 11:26 AM
