Fuel puddle in carb - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 06-19-2008, 2:18 AM Thread Starter
Fuel puddle in carb
I removed my air filter box to day and noticed a puddle of fuel in the carb for cylinder 2. After noticing this I started my bike up to see if that carb was spitting an excessive amount of fuel in. When it was running sure enough that carb was pouring more fuel in than the others. Has anyone else had this problem? How do you fix it?
moneypit is offline
post #2 of 4 Old 06-19-2008, 10:06 AM
Quoted: 6 Post(s)
Reputation Power: 26
Re: Fuel puddle in carb
You fix it by rebuilding the carbs, especially the  one with the broken float.
ghbzorro is offline
post #3 of 4 Old 06-19-2008, 6:40 PM
you mean you can see fuel coming up from the back of the carb? Is it coming out the hole the needle is going into? Sounds like you have a float trying to stick. If you can get to it (it's gonna be tough), try tapping it with a wooden handle screwdriver and see if it quits. May just be a piece of dirt in your needle seat.
cbr900racer77 is offline
post #4 of 4 Old 06-20-2008, 1:39 AM Thread Starter
Exactly theres fuel puddling down on the flap in the back of the carburetor when the bike is idling. When I shut the bike off fuel still comes up and threw the hole with the needle, leaving a nice puddle of fuel in the carb. I'll try tapping it hopefully that will do it. If not I'll pull the carbs off this weekend and clean them real good. Thanks for the tip.
moneypit is offline
Bikers in fuel protest here in UK.. LoopyLee General Discussion 34 06-11-2008 1:19 PM
Fuel in oil Scruffy Honda FireBlade 7 03-21-2008 1:01 PM
fuel leaking from carb yulianusl Honda FireBlade 4 08-15-2007 6:01 PM
Fuel in oil ?? jaim Honda FireBlade 5 03-18-2005 1:00 PM
