PROBLEM - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 06-19-2008, 5:56 AM Thread Starter
PROBLEM
Engine 60k miles year 2002
Plugs 15k miles (Iridiums – good for 32k)
Engine regularly serviced
Just happened this morning. Noticed a different ‘burble’ when slowing down for traffic & then the engine was erratic up to 3500RPM on small throttle openings. Sounds & feels like its dropping a cylinder most of the time but the odd time it kicks back into life. The idle speed has also dropped & is jumping from 1000 – 1300 RPM. Engine runs well as even above 3500 RPM & you would not know there is any problem.
I thinking it is one of the following:
- Bad sparkplug or plug gap has been reduced
- Bad or loose fitting coil/plug connector
- Frayed wire earthing at the cylinder head
- Water ingress to electrical at the head
The waetaher was terrible yesterday & I got caught out in torrential rain for about an hour & wet through some big puddles fast enough to throw water up over my screen so maybe that the cause.
Your thought please gentlemen or has anyone had a similar issue?
King Kenny is offline
post #2 of 6 Old 06-19-2008, 6:09 AM
HondaGalToo's Avatar
Reputation Power: 31
Re: PROBLEM
I didn't have any symptoms, but when my plugs were changed for the first time at 16k, the tech noticed that a couple of the coils were loose. No idea why that happened, as the plugs had never been out, maybe it's just something the bike is prone to?
HondaGalToo is offline
post #3 of 6 Old 06-19-2008, 8:16 AM
Re: PROBLEM
clean your air filter and run some sort of fuel injectors cleaner then check your spark plugs tho if you ask me 15k ona set of plugs is quite alot
kiai is offline
post #4 of 6 Old 06-19-2008, 2:52 PM
Re: PROBLEM
As much as it sucks you should probably pull the coils off the plugs and let it dry. I have had this happen when washing my bikes in the past.
kristribble is offline
post #5 of 6 Old 06-19-2008, 5:37 PM
Re: PROBLEM
Check "servo motor" and intake flapper/EGCV. Mine's kaput; bike stumbles below/about 3000 rpm. and idle is fluctuating. I've got about 90k miles on mine and something caused servo motor gears to strip. Bike is throwing no codes? Mine also sounds different with both intake flapper and EGCV not moving.
a80jet is offline
post #6 of 6 Old 06-24-2008, 7:53 AM Thread Starter
Re: PROBLEM
Problem has seemed to go away after the bike was left lieing up for a few hours after me thrashing it within inches of its life (was severly pissed off).
Issue was most likely short circuit/bad grounding due to water ingress during the bad weather.
Will check the plugs & coils in a few weeks time anyway when I change out the old rattly cam chain
fuel problem brett Introductions 3 11-30-2007 8:08 AM
Electrical Problem austinlh Honda CBR 600 3 11-16-2007 8:18 PM
Idle Problem MRBOOST Honda FireBlade 4 09-09-2007 4:47 PM
Electrical problem... sonik_fury Honda FireBlade 0 01-16-2006 8:07 AM
Steering problem Abjatrer Honda FireBlade 2 10-16-2004 3:43 AM
