'96 CBR900RR Slips from 2nd to Neutral While Accelerating - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 07-17-2008, 11:01 PM Thread Starter
My 1996 CBR900RR will pop into neutral when accelerating in 2nd gear. Does that sound like a bent shift fork? The other gears do not have any problems and otherwise the bike runs great.
Thanks for any help,
Mark
MarkCNP is offline
post #2 of 11 Old 07-17-2008, 11:54 PM
Re: '96 CBR900RR Slips from 2nd to Neutral While Accelerating
Sounds more like worn dogs to me.
post #3 of 11 Old 07-18-2008, 11:24 AM Thread Starter
Are dogs accessible from under the clutch, or does the engine and transmission have to be removed from the frame?
MarkCNP is offline
post #4 of 11 Old 07-18-2008, 11:52 AM
Forks and dogs require splitting the cases.
post #5 of 11 Old 07-18-2008, 11:57 AM Thread Starter
Looking at my maintenance manual, it looks as though the forks are accessible from under the clutch.
MarkCNP is offline
post #6 of 11 Old 07-18-2008, 11:58 AM
Reputation Power: 59
There is only one way to find out...
Twincam is offline
post #7 of 11 Old 07-18-2008, 12:05 PM
You're right - the manual does indicate you can pull the forks by removing the clutch and sump which could be done without pulling the engine.
post #8 of 11 Old 07-18-2008, 12:25 PM Thread Starter
Does that mean that the dogs are accessible from under the clutch as well?
MarkCNP is offline
post #9 of 11 Old 07-18-2008, 12:47 PM
The dogs are part of the gears themselves so, no.
post #10 of 11 Old 07-18-2008, 10:55 PM Thread Starter
Thank you for your help. Even though it's bad news, at least I know what I'm dealing with.
MarkCNP is offline
post #11 of 11 Old 07-19-2008, 12:51 AM
You could do the second gear fork first and see if it's better and you might be able to avoid splitting the cases.
Forks often get bent as dogs wear due to the rider kicking the lever in frustration or trying to hold the gears in and such so they need to at least be checked anyway when you replace the gears. A worn or bent fork can cause the dogs to not fully engage and eventually result in the dogs wearing round.
From neutral to first problem. leland Honda FireBlade 4 11-28-2007 10:57 AM
Clunk when shifting from 1st to 2nd cubulco20 Honda FireBlade 6 05-24-2007 8:31 PM
will 2000 cbr900rr rear shock fit 96 cbr900rr? wylier18 Honda FireBlade 0 01-22-2007 2:06 AM
clunking when shifting from 1st to 2nd? BadBrad Honda Naked Sportbikes 9 01-13-2007 12:52 PM
Clunky shifts from 1st to 2nd just_john Honda FireBlade 17 07-15-2003 8:25 PM
