cbr 929 - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 07-18-2008, 5:08 AM Thread Starter
cbr 929
just a question:How do you perfom a pressure check and what is the normal range for cbr 929
speed929 is offline
post #2 of 10 Old 08-03-2008, 10:34 PM
Re: cbr 929
fuel pressure check?
Jakemmi is offline
post #3 of 10 Old 08-04-2008, 2:43 AM Thread Starter
Re: cbr 929
no no.not sure for the exact word but i meant what is the normal cylinder pressure or compression in the cylinder.i was thinking to overhaul the engine because it has already has 47 000 miles and was wandering is it time yet?stiil runs fast it goes 290km without a problem but--high mileage?any suggestions will be apreciated!
speed929 is offline
post #4 of 10 Old 08-04-2008, 3:04 AM
Re: cbr 929
Ah.. a compression check. remove the fuel tank and the air box so you can finally see the top of the engine. remove the spark plugs, and you might want to see if theres a way to ground the spark for when you crank the engine over, because some styles of ignitions can be damaged if the spark isnt grounded, then you just thread a compression gauge into the spark plug hole. make sure you open the throttle all the way to allow maximum airflow to the engine. and i just checked my manual and it says you should have 178 psi in the cylinder. so i think as long as your not below 160 or so you got a pretty strong engine
Jakemmi is offline
post #5 of 10 Old 08-04-2008, 3:40 AM Thread Starter
Re: cbr 929
thank,s a lot buddy where i can get the compression gauge by the way.DAMN WAS JUST READING JUSTICE FOR JOHN.
WISH YOU A SAFE RIDING
speed929 is offline
post #6 of 10 Old 08-04-2008, 3:42 AM
Re: cbr 929
you can get a compression gauge at most auto parts stores or even wal mart. you just gotta make sure you have the right size threads on it for your engine. mine happened to come with 3 different size threads because its a snap-on and rediculously overpriced.
Jakemmi is offline
post #7 of 10 Old 08-04-2008, 4:00 AM Thread Starter
Re: cbr 929
EYAH that.s why i asked because i know the tread sized is 10x1.0 which is rare for the most auto shops.i recently had to repair a blown spark plug and i couldn.t find that size tread chaser.so i had to buy a time sert spark plug repair kit for $250 but it worked just fine,insted of paying over 2000 as was quoted at a motorcycle repair shop&dealer.buti will look for one ,i,m not familiar with the word snap on but will figure out something.appreciate your help and advices.thank,s
speed929 is offline
post #8 of 10 Old 08-04-2008, 4:03 AM Thread Starter
Re: cbr 929
is it normal to hear like knocking sound from engine when drive and squize the throtle?or is ti a camshaft chain loose
speed929 is offline
post #9 of 10 Old 08-04-2008, 2:06 PM
Re: cbr 929
thats not normal.. it could be the cam chain, or if its more of a ticking noise that could be your valves. if its a knock though hopefully is just something to do with the cam chain because thats an easier repair that something in the bottom end of your engine, such as a connecting rod bearing or whatever. i can look in my manual later today and see if theres a way to check for cam chain tension
Jakemmi is offline
post #10 of 10 Old 08-04-2008, 3:25 PM Thread Starter
Re: cbr 929
i have the valve cover off just 2-3 weeks ago the chain looked ok and tight but was wondering.thank,s alot man.i will be looking for the gauge that you told me for compression check
speed929 is offline
cbr 929 speed929 Introductions 2 07-12-2008 8:41 AM
2001 CBR 929 & 2006 CBR 1000 FOR SALE! 92EGSi For Sale 1 03-11-2008 11:53 AM
CBR 929 andrew2001 For Sale 2 06-19-2007 11:33 PM
Will a 2001 CBR 929 Ohlins rear shock fit a 2002 CBR 954? 147RWHP Honda FireBlade 10 03-01-2006 7:19 PM
Will the oil filter from a CBR 900 1999 fit a CBR 929 2000 ? chaosExpanding Honda FireBlade 7 03-05-2004 4:31 PM
