954 oil light - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 07-19-2008, 12:13 PM Thread Starter
954 oil light
I have a 02 954 w/ 11,000 miles, the problem is that the oil light comes on above 4000 rpm, it just started this. Could it be the oil pump ? oil sending unit ?? Any info would be helpful. Thanks, Rick
nuckin_futs1 is offline
post #2 of 5 Old 07-19-2008, 1:47 PM
Re: 954 oil light
You should check the oil pressure I'd say.
Is there plenty of oil in the engine?
How old is the oil?
post #3 of 5 Old 07-19-2008, 4:48 PM Thread Starter
Re: 954 oil light
The oil was just changed less than 500 miles ago , i put in 5w40 Rotella T full synth. The oil level was the first thing i checked. Iv had several sport bikes in my time and never had a problem like this. So i figured that i would hit up you guys on fireblade.
post #4 of 5 Old 07-20-2008, 1:32 AM
Re: 954 oil light
What oil weight were you running before and what has the ambient temperature been like?
Has the engine ever been apart? If the sump has crap in it the filter on the pump could be clogged reducing oil flow at higher revs.
The pressure relief valve is immediately upstream of the pump and before the filter. A blockage in the filter at higher revs could increase the pressure enough to bypass through the relief valve and also reduce the pressure upstream.
If the spring is broken in the relief valve that will also cause low pressure.
An unlikely problem but possible if the engine has been heavily crashed or blown up before is a cracked gallery. I cleaned a 302 block once for a rebuild and couldn't get good pressure. Finally discovered a cracked gallery inside that was squirting the oil straight back into the sump.
First, you need to check oil pressure to determine if there's a problem. You should have around 70psi at 5400rpm.
post #5 of 5 Old 07-20-2008, 2:17 AM Thread Starter
Re: 954 oil light
Thanks for the replys,,,, im doing a oil pressure test tomorrow, The motor has never been apart, or crashed , so im not sure what has gone wrong. I was running 10 w 30 in it before i went to the Rotella T , So thanks agian for the input,, now lets hope that the oil pressure is close to 70psi.
Oil light on Axelstaffy1 Honda FireBlade 0 01-24-2008 12:34 AM
oil pressure light bladefighter Honda FireBlade 3 07-11-2007 8:46 AM
CBR600 F2 Oil Light? dcgreen Honda CBR 600 1 05-07-2006 5:48 PM
Oil light @ idle????? Intimidator Honda FireBlade 12 08-31-2005 10:09 AM
Oil Light still on..... victoRR Honda FireBlade 8 09-14-2004 6:09 PM
