gearshift problems
Hi guys,
Alittle help if possible, just sifting through the serach function as i go!
Just tried to take the RRY 2001 out for a blast and suddenly found i cant get above 2nd gear!!!!! VERY clunky going into gear and easy to find neutral rather than 2nd when trying to shift up. Wont go above 2nd atall.
Feels like the gear pedal is not returning properly after a shift. The chain is due to be replaced and is pretty much at the end of its life but is a loose chain likely to be the sole cause or is it a dreaed gearbox issue?? Bike has 10k on the clock and is otherwise mint. Should say that it felt alittle clunky last time i used it but never any problem like this and now after 8 weeks of no use instant issues! Any help much appreciated before i haul it down to the local indy bike shop.
cheers!
