code 35 and servo motor - Honda Motorcycles - FireBlades.org
post #1 of 1 Old 07-21-2008, 6:01 PM Thread Starter
Hi guys,
Yesterday i posted that my bike was having gear selection related issues possibly due to a worn chain or worse. Now found that the gear lever footrest bolt was loose causing alot of un-needed movement in the assembly and presumably the poor gear selection. Took bike out and tested and much better so just as i was thinking great the FI and red light come on
Its throwing error code 35 for the servo, i guess its a stripped gear/stone jamming as in other posts. Having new chain and sprockets and service next week, should i get them to replace the motor if buggered or worth first jumpering the non-used plugs which i read are under seat? or will this light just keep re-occurring? assume i can ride fine until then. How easy to access the valve to check that nothing is jammed. have remus race can but otherwise standard. mechanically inept here so any pointers welcome!
Cheers!
gilessav is offline
954 EGCU and air intake servo motor maxredline Wanted 0 05-11-2007 12:16 AM
954rr check engine code 35 BoxxBanger1 Honda FireBlade 1 05-21-2006 2:53 AM
2000 929 Error Code 35 Duess Honda FireBlade 5 05-05-2006 1:24 PM
How do you bypass servo motor and pot. on a cbr 929? monoskimt Honda FireBlade 3 07-18-2005 6:24 PM
Error Code 35 ? AfterShock Honda FireBlade 15 08-22-2003 1:35 AM
