why does my bike studder@ first 2500rpms? - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 07-23-2008, 7:06 AM Thread Starter
why does my bike [email protected] first 2500rpms?
i have an 04 1000rr with a slip on jardine, stretched 8 inches, pc3, and it sputters at the first 2500 rpms on take off only. the response is minimal on throttle, and the more throttle i give it makes it shudder harder. it did this before pc3 and i figured it would help but didnt. i do have the flapper valve removed. what can i do to get rid of sputtering and/or get better throttle response?
majikkev is offline
post #2 of 8 Old 07-24-2008, 8:09 PM
Re: why does my bike [email protected] first 2500rpms?
wow honestly i have the same problem on my 929 but i dont have the flapper valve removed but i have been adjusting my pc3 here in there after i installed the map for my setup and i felt that if i went leaner on the low area it helped alittle bit better. but if you do find out something better please let me know also thanks
Gregory Waters is offline
post #3 of 8 Old 06-10-2009, 12:09 PM
Have either of you resolved that issue with your bike? Mine 02' 954 does the same thing when taking off slow and easy and when I give it more throttle it won't stop until about 6000 and then takes off....not sure what the deal is?
USMC954RR is offline
post #4 of 8 Old 06-10-2009, 1:16 PM
Reputation Power: 59
Try removing the PC3 (disconnect it) and see if it makes any differences - some times the map can drop and go bad.
Twincam is offline
post #5 of 8 Old 06-10-2009, 4:45 PM
I don't have a PC3.....but thought about getting one. Did you take the flapper out of yours or eliminate the HTEV? I also thought about doing that along with adding a PC3 and a HR1 Exhaust....
post #6 of 8 Old 06-10-2009, 7:12 PM
I was referring to Majikkev's first post... Just trying to isolate the problem (process of elimination)
The flapper is only a flap which opens and closes to restrict the air flow to help control the noise being emitted... Removing it from what I have read doesn't actually gain you any extra BHP, just helps save on weight.
Twincam is offline
post #7 of 8 Old 06-11-2009, 1:11 AM
Reputation Power: 15
just outta curiousity, checked the plugs lately??
sonik_fury is offline
post #8 of 8 Old 06-11-2009, 6:37 AM
No, but once I return from deployment I plan on doing a big tune up...
Why a fireblade is a bad first bike.... -Z- New Rider Orientation 93 06-07-2011 8:36 PM
Why does my title Say different then my bike Xuracing General Discussion 4 07-04-2008 7:39 AM
Why is a 600cc forbidden as first bike. andrebanga General Discussion 110 03-26-2008 3:00 AM
why does it say that SilverBullet started my ramp thread? TCD General Discussion 1 11-23-2003 9:11 AM
