Why would the fual pump fuse blow - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 07-25-2008, 9:14 PM Thread Starter
As per the title... why, after a journey of 3 hours (1 to go) would the fuel pump fuse blow?
I got rescued by the rac and I checked everything except the fuses which the rac guy did. Couldn't find a fault but pump wasn't priming. Got recovered home and started stripping it down and found a fuse outside the fuse box which was blown. Replaced that and pump primes. Argh!!!!! Never trust anyone else to touch your bike is my advice - so pissed off, missed the lads weekend.
Anyway (deep breath)... I've put the new fuse in and it runs. What do I do now? Will it blow again? Do I risk the run up north again tomorrow so at least I get one night of poker? Why do fuel pump fuses blow after 36k miles, 7 years and no warning?
Help!
Ta,
Mark
dern is offline
post #2 of 6 Old 07-26-2008, 10:50 AM
Reputation Power: 12
Re: Why would the fual pump fuse blow
May be the beginning ailments of a bad fuel pump. Drawing a little too much at whatever point it blew the fuse. My 2cents.
bibledriver is offline
post #3 of 6 Old 07-27-2008, 6:28 PM
Seb
Maybe the fuse just got worn out. After 7 years thats likely to happen. I would bring a spare thou
Seb is offline
post #4 of 6 Old 07-28-2008, 9:26 AM Thread Starter
Unfortunately I wasn't able to change one thing at a time and therefore find out what caused it as I didn't want to miss the second half of the weekend. I swapped the pump out for my spare, checked for shorts (couldn't find anything), put a new fuse in (took some spares) and stuck some foam in to hold the fuse holder a bit more firmly and got there and back (320 miles) with no further issues.
Cheers,
Mark
dern is offline
post #5 of 6 Old 07-28-2008, 11:20 AM
Good move. I would have done the same!
Enjoy
post #6 of 6 Old 07-29-2008, 2:25 AM
The most common cause, other than a short, of a fuse blowing is too high of a load. In your case it definitely could be the pump. You could use a lab scope and a current probe to measure the amp draw and compare it against a known good pump. A bad fuse could also be a likely problem. GM had a service bulletin about using cheap fuses from places like tool town, etc. that actually wouldn't blow and the wires were melting, so it can go either way.
soreknee is offline
f4i blowing fuel pump fuse E_RacK Honda CBR 600 12 06-08-2007 12:50 AM
Why would anyone do this? Northern RR Off-Topic 4 10-12-2005 12:52 PM
Welcome to the newest blow in! RPinOZ Australia 18 04-11-2005 2:12 AM
Why would you name your child this? WetShrub Off-Topic 14 06-15-2004 2:16 PM
(Spoiler) Why I would be in jail now. risc32 Road Racing: Professional 35 03-10-2004 9:13 PM
