Can I use ethanol in my 929? - Honda Motorcycles - FireBlades.org
post #1 of 30 Old 07-26-2008, 2:51 AM Thread Starter
Here in Thailand if you are outside of Bangkok most of the stations only sell "gasahol." It is 95 octane, 10% ethanol. Will running ethanol do any damage to the fuel system?
Millsee is offline
post #2 of 30 Old 07-26-2008, 3:23 AM
Re: Can I use ethanol in my 929?
all gasoline sold at gas stations contain a certain percentage of ethanol... you'll be fine
cbrsmurf is offline
post #3 of 30 Old 07-28-2008, 12:25 AM
Reputation Power: 21
Thats news to me!
And I thought it was something that was added, hence manufacturers coming out and saying which models are suitable to work with E10 or other ethanol levels.
dicknose is offline
post #4 of 30 Old 07-28-2008, 1:49 AM
next time you are at the pump, check out the labels, it'll say the gas is x% ethanol
there's also a topic about it in wikipedia
Gasoline - Wikipedia, the free encyclopedia
cbrsmurf is offline
post #5 of 30 Old 10-09-2008, 6:03 PM
How do your bikes run on these ethanol blinds?
Maness1220 is offline
post #6 of 30 Old 10-09-2008, 8:33 PM
Reputation Power: 12
Like a bat out of hell. According to some pseudo-scientific tests, it will lower your miles per tank a little bit.
bonham is offline
post #7 of 30 Old 10-09-2008, 9:58 PM
yep gas milage drops big time
bignibb is offline
post #8 of 30 Old 10-09-2008, 11:58 PM
thats bull..
here in minnesota a lot of people run e85 and e98. e85 yields a roughly 105 octane rating while using 30% more fuel to atomize correctly.
but when using 10% ethanol gas here (every single gas station) the gas mileage doesnt drop noticeably, it actually increases in many cases (turbo cars, high compression vehicles) increases burn quality, its also a cleaner burn.
honda3x23 is offline
post #9 of 30 Old 10-10-2008, 12:34 AM
Ethanol Gas Mileage - Increase or Decrease? Ethanol - Production of Ethanol Fuel
For those interested in reading about it, it appears to depend on the blend. Have a look at the study run by the American Coalition for Ethanol.
bonham is offline
post #10 of 30 Old 10-10-2008, 12:40 AM
During the winter most gas you buy has about 10% ethanol. This is to help fight pollution. It takes more energy to burn it. During the summer gas usually has a lower amount. E85 is 85% ethanol and 15% gas. I believe the Flex fuel cars have a higher compression ratio allowing it to burn. Since your bike has a high ratio too i think it would burn just fine. Prob get lower mpg.
HondaForLife954 is offline
post #11 of 30 Old 10-10-2008, 12:46 AM
Quoted: 198 Post(s)
Reputation Power: 25
Octane and compression ratio do not go hand in hand. The head design plays a big part as can cylinder size.
lanbrown is offline
post #12 of 30 Old 10-10-2008, 1:42 AM
what!?
this is the second time someone has gave poor information, honestly please dont post unless you have a clue!!!!!
octane rating is pretty much the ability for fuel to be compressed until it combusts, compression ratio is the distance from the bottom of the piston stroke to the top of the piston stroke (bdc to tdc) they are in fact DIRECTLY related in every way. basically not enough octane, detonation, holes in pistons etc.
(yes the firing chamber does effect it but all you're doing is changing the distance from tdc)
post #13 of 30 Old 10-10-2008, 3:24 AM
The head design can play a part in it due to volumetric efficiency.
During most of the rev range you are getting less than 100% cylinder filling due to valve overlap (the intake valve may be closing while the piston is still descending or the exhaust valve is still open when the intake opens) and other factors. You may well have a mechanical compression ratio of 13:1 say but if you only have 80% of the cylinder filled with mixture you are not compressing it anywhere close to detonation. On the other hand, you could be running a 12:1 ratio and still experience detonation at certain points in the rev range if the engine is breathing exceptionally well due to cam and head design where you might see 110% volumetric efficiency - that's stuffing 275cc of mixture into a 250cc cylinder.
A very poorly designed engine could perhaps run 14:1 on standard pump gas with no detonation at all.
post #14 of 30 Old 10-10-2008, 8:36 AM
WHAT, any evidence behind this?
btw thanks for the explanation on scavenging, but i got chamber size covered already, thanks cheif
post #15 of 30 Old 10-10-2008, 9:34 AM
In the US you can't buy gas without Ethanol added, unless you buy race fuel only...that would be expensive. What I have heard, and had confirmed by a couple of mechanics is that this amount of ethanol mixed with fuel will deteriorate any rubber parts in your motor, usually seals and the like. Not like acid would, but they will deteriorate considerably faster than using only gasoline. I am honestly waiting for all my seals to blow out and see what the manufacturers are going to do about this, design new seals that will withstand the new gas, replace the motor and rebuild with said seals....I highly doubt they will do any of this but the bottom line is, these motors were not made with ethanol in mind and will not last as long as they may have using straight gasoline with out hte ethanol additive.
my .02
DragonRider is offline
Is it ok to use Castrol GTX 10w30 in my 00 929? blue89turbo Honda FireBlade 65 03-06-2010 1:03 AM
best oil to use in my RC51? theheat General Discussion 8 10-28-2007 1:47 AM
Ethanol sucks Pete Off-Topic 64 08-04-2006 7:36 AM
PC3 map, what can I use. slodsm Honda FireBlade 1 01-11-2005 11:23 PM
Can I use 954 fairings on my 929??? Hondalush318 Honda FireBlade 4 05-14-2004 1:57 PM
